I need a cheap amp for a kicker L7
Username: Moheevi
Post Number: 131
please help
Username: Nyyfan13
Fi SSD USA
Post Number: 2233
voice configuration?
and what is cheap?
Username: Moheevi
Post Number: 132
dual 4 ohm....like 200? lol cheapest one you can find
Username: 40hz
Post Number: 10
hey mtt,got to www.hifisoundconnection.com and get a kicker kx600.1 for 169.00.its a refurb but mine works great from them.or got to crutchfield.com and get a profile 1000m. with a 3 yr warranty. I had one on my L5.it pounded,but I wanted a little more so I got the kicker amp.birth sheet on the kx is 700 watts. the profile is a mono amp,300 watts at 4 ohms and 500 at 2 ohms.with a remote bass nob. good luck.either one will make it loud,well, its loud to me.lol.
Username: Van_man
Boston South, MA
Post Number: 1701
his is your lucky day.
Im selling this one. Works like new Looks very nice, but 1 small plate snapped. Mounting screw in bracket stipped, so the guy jest pulled it out breaking the plate. Does not effect performance. Circled in red in pic.
Ill give it to you for $225 shipped.
Anybodt need one? $225 + shipping
Power ratings for this amp are listed as
300 watts into 4 ohms,
600 watts into 2 ohms,
1100 watts into 1 Ohm.
Output Power 4 ohms
533 watts @ 14 volts;
482 watts @ 12.8 volts;
Output Power 2 ohms
791 watts @ 14 volts;}
643 watts @ 12.8 volts;
Output Power 1 ohm
997 watts @ 14 volts;
886 watts @ 12.8 volts;
246 watts @ 10.5 volts;
Username: Moheevi
Post Number: 133
How do you tell how many ohms a sub is by looking at the sub?
Username: Van_man
Boston South, MA
Post Number: 1704
On each coil of the L7 it says 4 ohm, Right? so dual 4 ohm. 1 L7 Dual 4's wire down to 2 ohm loads.
That sub is 750wrms (but will take 1000 all day)
And this amp does 791 at 2 ohms, so its a nice match.
So whatever amp you decide on, make sure its power is 750-1000wrms at 2 ohms. Some suggestions (Daves)up there ^^^ are kinda tame for that sub.
