Like
Ssxvs3515whichisbetter
Username: Troy81
Tavernier, Fl Us
Post Number: 1434
ssx 15 vs DD 3515.... 2 in the same size box tuned the same, SQL?
Username: Jblanford
Post Number: 228
prolly the ssx if you can power it right...i think the 3515 will get loud with less power though
Username: Safe_cracker
Chicago, IL US
Post Number: 2287
SSX is more compared to the 9515. Polo..
Username: Cenus
Hicksville, Ohio
Post Number: 2748
the ssx needs 2500+wrms to get moving, the DD needs 1500wrms+ both will get very loud. under 2000wrms i'd say the DD will be louder but above 2500 i'd say the ssx.
Fi Audio BTL
Post Number: 8506
ssx FTMFW and then some.
Username: James1115
Use a simple...
Post Number: 8488
agreed with the rest^
Username: Basshead86
FTW
Post Number: 9703
isyourspacebarbrokeorsomethinglikethatbecauseitsuremakeseverythinghardertoread
Username: Adddisorder
West palm, Florida
Post Number: 2564
compleatly depends on how much power your going to run
Username: B101
DD, RE, FI, TREO, KICKERUSA
Post Number: 4110
SSX is louder... dont tell me a SSX isnt loud on 500rms!!
I know better... like Polo said its more compared to the 9500 not the 3500!!
lol
Chicago, IL US
Post Number: 2294
I had my SSX on 1400+ and it was louder than my SX on the same power in the same enclosure using the very same amp. The difference was between a headache and a migrane... Polo. :-O
Username: Imperial_designs
Lafayette, Louisiana
Post Number: 55
no way the SSX can kill the 3515, in fact im willing to bet that the 3515 would at least keep up for almost the half the cost....
Username: Oglejust
RE SX, USA, Il
Post Number: 676
both awesome subs but the ssx is prolly louder
Facebook
Shop Related Deals
Directory
