Wiring question asap
Username: Fatkid
tonawada, Ny
Post Number: 55
how can i wire a 4 channel amp to two subs. they can be ran 2 or 8 ohm. diagram/picture if poss. thanks.
Fi AudioBTL
Post Number: 8285
what kinda amp are we talking about here. most of the mutlchannel amps can be brided but there are some that can't be bridged.
if your amp is bridgeable, you would connect the + on your sub to a + on one channel and the - on the sub to the - on the other channel.
Fi AudioBTL
Post Number: 8286
Username: Fatkid
tonawada, Ny
Post Number: 57
thanks. i havent gotten an amp yet i was just try to figure it out .
Username: Tjmutlow
Post Number: 3422
you can only do it that way if it is a single 4 ohm or dual 2 ohm sub...
