91 gmc sonoma reg cab
Username: Chaossonoma
I have a beastly 91 gmc sonoma reg cab and i wanna put a 10" punch 1 sub behind the seat. I was gonna build my own sub box but i dont know how i should make it or if it will have enough air flow. if you know how plz email afro_11@hotmail.com with detailed instructions. thx
Username: Logan__tille
RE XXXYeah its 15 ...
Post Number: 3107
Do you already have a p1? If you dont, please dont buy one.
Whats a pl?
Post Number: 3110
punch 1
Yeah i already have one I ended up buyin it cause it was on sail with an 800 amp
Post Number: 3111
ok, is it going ported or sealed.
Username: Safe_cracker
Chicago, IL US
Post Number: 2134
Build this box for your daily, 2 type R 15's 4.5 cf each with a total of 8 four inch aeros tuned to 41hz, did a 153db. Polo..
Username: James1115
Use a simple...
Post Number: 7814
that wont fit in a reg cab pick-up Polo
Username: Juliob
Santo DomingoDominican Re...
Post Number: 3655
damn polo! looks like a plumber's van
ported or sealed? srry im kinda new to this sub box buildin thing, but my dads a master carpenter
Username: James1115
Use a simple...
Post Number: 7856
with your space limitations I would go sealed.
i still dont know what sealed means
Username: Dsmith07
LaGrange, NC US oF A
Post Number: 278
my friend has a 10" p1 in his f150 ext cab truck and it sounds ok for what it is...what amp are you running?
i have a p2002 amp
