What do you guys think about this box?
Fi AudioBTL
Post Number: 7760
its a rough sketch. of course i would use a calculator to fine tune everything.
Username: Cenus
Stonerville, Ohio
Post Number: 2572
looks like a bandpass box, what order is it 4th? bandpass boxes are very hard to get good sq from them but they useally have good spl results.
Fi AudioBTL
Post Number: 7764
i don't know what order bp that is.
i think it will hit good on the mic though.
Username: Rovin
Trinidad & T...
Post Number: 10084
check which order it is here >>>>>
http://www.diysubwoofers.org/ .....
Username: Bump05
We Stay Fly, 18 SX USA
Post Number: 478
imo i dont think it will be that great...i build almost same exact box.. and my standard ported box hits way way way harder.. personally dont like bandpass
Fi AudioBTL
Post Number: 7765
yeah its a 4th order.
this type of box requires less cuft and can get louder in the mic if done correctly.
Username: Bump05
Post Number: 479
then do it..if u plan on putting your btl's in there if they were mine i would put them in a standard box port back subs up / or facing in the car so i could see there pretty faces
Fi AudioBTL
Post Number: 7766
well i wasn't asking if i should do it or not. i was asking some opinions on this type of box.
i am already building a standard ported box. but you know how it is when you compete. you want to gain that extra db here and there without actually putting more power on it.
Username: Frkkevin
Post Number: 2089
damnit chad just do your two subs on the passenger side and port the drivers side.. that will be the best setup for your car :-)
Fi AudioBTL
Post Number: 7773
cut me some slack kevin. i am just throwing out ideas here. lol.
Username: Adddisorder
West palm, Florida
Post Number: 2218
chad if you want bandpass box go on caraudio.com and search for a member named 80 inches hes awesome at building/designing bandpasses.
