///The best components for sound quality\\
Username: As007
I currently have the Focal K2P component set in my car, which is a 2001 330ci, they are being powered by a JL 300/4 amp. I want to upgrade to something better, but what?? I listen to a lot of trance so detail is what I am looking for. Price range is under $2,000.
Username: Tc_skier
Post Number: 39
I'm assuming you have the 6.5" set of K2P's, and that you wanna stick with a 2 way set?
Probably worth a look: http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=4749
Username: As007
Also another question, say I was to keep the K2P's would going with a Zapco or Audison 2channel amp make them sound any different than they do now running off the JL 300/4?
Username: N2audio
Lawrence, Ks USA
Post Number: 1038
if the new amp is more powerful, and the speakers can make use of that power -- maybe. Otherwise, no.
Username: Delsole
Post Number: 1153
ebn though those amps are clealy better and put out more power i cant see a noticable difference in the way the speakers sound. mabe a little bit but only because of the extra power.
