Box question
Username: Holt_champ
Htown, MI
Post Number: 221
is there an easy way to make a sealed box ported?? i made a sealed box and now i want it ported?? any help would be apreciated. thanks
Username: J_baby15
Kentucky
Post Number: 904
Add a PVC port or flared port.
Htown, MI
Post Number: 222
how would i do that. what is a pvc port??
Username: Dustin3
Tigard, OR U.S.
Post Number: 4230
a pvc port is made out of pvc pipe, with most likely a flare on the ends, which is like an aero port. you basically have to calculate the length of the aero port and then cut the hole in the box, and ur good :-)
Htown, MI
Post Number: 225
would that be as good as a vented box??
how far should the port go into the box? half way, 3/4, what is a good length?
Username: Adddisorder
West palm, Florida
Post Number: 1983
get 4" flared ends from partsexpress.com
then some 4" pipe from homedepot or just get the kit from parts express.
anyway depends on the size of box as to how long to make the port
Htown, MI
Post Number: 232
ok, well my box is L:24 W:33 H:16, i have 2 Q's that are goin into it and i need to port the box so i can get them louder. how long would you make the ports.thanks for all of you help.
Username: Rick_ross
Post Number: 738
what do you want it tuned to and yea its as good as a vented box and sometimes better if you do it good
Htown, MI
Post Number: 233
what do you think would sound good for 2 15" Q's. i have never had a ported box
Username: Rick_ross
Post Number: 742
i would do 35hz
Htown, MI
Post Number: 236
how long would i make the aero ports? also how wide? is 4" good for the size of my box?
Username: Stnorris
Davenport, IA US
Post Number: 1759
i dont know if that box is really going to be big enough for 2 qs ported. you might just wanna make a new box..
Htown, MI
Post Number: 240
i cant go any bigger. that is as big as my trunk goes so i will have to make it work.
Username: Rovin
Trinidad & T...
Post Number: 9917
use this 2 figure out how 2 do ur port size/length
http://www.carstereo.com/help/Articles.cfm?id=31 ..........
Fi AudioBTL
Post Number: 7346
can someone give me a link to aero ports on partsexpress. please.
