Still don't quite understand this, pls explain
Username: Pitbullguy
Chi Town
Post Number: 63
So i'm gettin rdy to set up a couple 12" assassins in the near future(300rms each;600rms total).
ppl have reccommended a kicker kx600 amp which does 300rms at 2ohms and 600peak at 2ohms.
the subs need 300rms each and im under the impression that "peak" means the amp can't sustain that wattage for extended periods of time.
wouldn't the subs be underpowered?
Username: Tdawg30
Ohio USA
Post Number: 548
no the amp does 600 rms @ 2 ohms......300 rms @4ohms
Username: Rick_ross
Post Number: 628
that amp does around 700 rms at 2 ohms
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3390
peak means ABSOLUTELY NOTHING. just pay attention to rms specs
Chi Town
Post Number: 64
hmmmm this says it does 300rms at 2ohms.
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1331443/vpcsid/0 /SFV/30046
is that just a misprint then? should factory renewed worry me?
Username: Tdawg30
Ohio USA
Post Number: 549
yes its a misprint and no........factory refurbs are just as good as new.might have some scratches but thats all.
Username: Adddisorder
West palm, Florida
Post Number: 1828
yeah or get a zx750.1 does around 900rms really a tad bit more then those subs need but if you ever change your set up its still a great amp to keep.
the assassins can take 400rms no prob. 450 is the most you should feed them.
Post Number: 3400
sorry i read it too quickly and didnt realize you were confused if it put out 300rms or 600 rms. i though you just didnt know to go by peak or rms. sorry
Username: Tjmutlow
Post Number: 3185
what voice coil config are those subs/
Chi Town
Post Number: 66
single 4 ohm ty
Chi Town
Post Number: 67
what does that mean, can they even run at 2 ohms?
Username: Livin_loud
Ny
Post Number: 435
no. it just means you wire them differently
Post Number: 3410
2 SVC 4 ohm subs can be wired together in parallel for a 2 ohm load or in series for a 8 ohm load.
Ny
Post Number: 438
whoops i misread that, my bad
Username: Tjmutlow
Post Number: 3191
the zx 750.1 would be great for those,
