I'm gonna try....
Username: Mvplefty12
Pinellas, FLA America
Post Number: 204
I'm going to do 2 15" CVR's on 1100 watts in a BIG sealed box in the civic... I wanna see how loud that'll get... Any suggestions?
Username: James1115
Ct
Post Number: 7412
whats the rms on those? 600?
Post Number: 205
Username: James1115
Ct
Post Number: 7414
be carefull not to go to big sealed. The power handling decreases in larger sealed boxes because it makes the sub appear to be IB(Infinite Baffle)
Post Number: 206
I was thinkin around 3.75 cu. ft sealed? smaller or what?
Username: Adddisorder
West palm, Florida
Post Number: 1832
for one that is probly to big 2.5 cubes should be a decent size
Post Number: 207
you think the 2.5 will work? they reccomend at least 1.6 for each sub...
West palm, Florida
Post Number: 1833
i wouldnt go huge. like james said that can be a bad thing. personally i would take the biggest reccomened box and make it .5cu bigger if you want
Username: Rick_ross
Post Number: 640
if you have at least 500 rms for each sub put them in 1.8 cu ft each with a little polyfill
Post Number: 209
so, 3.6 cu ft. and polyfill will get those 15"s loud?
Username: Cenus
4, 20
Post Number: 2452
3.6 total yes they will get loud, i'd say upper 130 db area.
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3414
^^that is a good idea. dont want a big box with over their rms. and polyfill will give you a little extra "deepness"
Username: Rovin
Trinidad & T...
Post Number: 9759
yeah - too oversized sealed box sounds like POO ! ............
