How does this look?
Username: Tcrowden
Ocean springs, Ms.
Post Number: 29
Just got finished with all my wire runs.here is a few pics.
Username: Logan__tille
Www.Audioque.comUSA
Post Number: 2435
where?
Username: Tcrowden
Ocean springs, Ms.
Post Number: 30
Username: Tcrowden
Ocean springs, Ms.
Post Number: 31
sorry pics were to big had to resize.
Www.Audioque.comUSA
Post Number: 2436
looks nice. What size are the cables?
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 3381
looks good. can look better though, just drill holes in the amp rack so they come up through the amp rack instead of across it. and you can run the wires under the carpet until i comes up underneath the amp amp rack so you dont see them there either. It's alot of work i know, but when you look at it when your done.... you'll see.
Username: Tcrowden
Ocean springs, Ms.
Post Number: 33
4ga.dont know if i'm gonna keep this way or turn the amps so i can get to the gain and crossover controls
Username: Tcrowden
Ocean springs, Ms.
Post Number: 34
Stinger -SWCKH42 multi amp kit
Username: Sb2012
Iowa US
Post Number: 441
looks good. but i agree with trevor itd look even better if u hid the wires...:-)
Username: B101
DD, RE, FI, TREO, KICKERUSA
Post Number: 3813
looks good, for a average install...
but take Trevors advice!
Username: Tcrowden
Ocean springs, Ms.
Post Number: 36
its still a work in progress
