Gold Member Username: Extrmndor3Fack you taco vendor , fack drivin... Fakin crybaby Post Number: 2526 Registered: Feb-06 | wat up peeps well i juzz tested my subs on 60 watts rms at 8 ohms home stereo but i wired the sub to 2 ohms expecting 80-110 rms those lil b1tches bang hard and clean @ss hell like i said they are cleaner and louder than assasin i juzz tested one with 500 rms but did int got the video yet cuz is too dark on the garage ill take it tomorrow yeah boooooiiiii mid 150's for sure http://s79.photobucket.com/albums/j128/extrmndor3/?action=view¤t=phoenixgo ldoctanerzrated.flv |
Gold Member Username: Extrmndor3Fack you taco vendor , fack drivin... Fakin crybaby Post Number: 2527 Registered: Feb-06 | |
Gold Member Username: Extrmndor3Fack you taco vendor , fack drivin... Fakin crybaby Post Number: 2528 Registered: Feb-06 | |
Gold Member Username: Extrmndor3Fack you taco vendor , fack drivin... Fakin crybaby Post Number: 2529 Registered: Feb-06 | excursion is amazing sorry abotu the camera people cant pick up the louds really clear but yes they bang bump |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3239 Registered: Sep-04 | dont get hope up too high for mid 150s. if it were so easy steve meade would be hitting mid 160s... |
Gold Member Username: Extrmndor3Fack you taco vendor , fack drivin... Fakin crybaby Post Number: 2531 Registered: Feb-06 | he got his set up for sq hes box is tuned at 30hz plus he got a suburban his truck isssss wayyyyyyyyy bigger than mine explorer are the easiest trucks to get loud plus they peak at around 42-46hz my box i think is gonan be tuned at 35hz and they are not too big, im not hopinh high mid 150's well at least 150 |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3241 Registered: Sep-04 | i think you can def hit 150. but it seems once you break 150 every decible is just that much harder. meades made be tuned 5 hz below yours. but he has 20kw and 4 18s... thats 50% more cone area than you. |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3243 Registered: Sep-04 | meade's may be*** |
Gold Member Username: Extrmndor3Fack you taco vendor , fack drivin... Fakin crybaby Post Number: 2532 Registered: Feb-06 | meade is hittin 159 db's and yeah when u get to 145 every db's is getting harder because of the resistance . heres more info Technical stuff: 0. If you can ever get to measure the higher db levels of 145 to 155 of something you will definitely notice it getting harder and harder to get louder (more db) especially if your using electronic amplifiers and speakers. This effect keeps getting more and more noticeable the higher db level you go. To go from 130 to 132 db is very easy, from 140 to 142 is O.K., from 150 to 152 db is difficult and from 160 db to 162 db it is very hard, you will need lots and lots more power, sometimes double or maybe triple. This effect is called "POWER COMPRESSION" (technically, it is "NON-LINEARITY"), and most sound engineers hate it, but get used it. It is the result of a lot of causes like: 1. superheating and overheating of everything, heat is bad, and its everywhere 2. resistance and ohm load changes (long term and instantaneous) 3. magnetic field non-linearity from heating, oversaturation to desaturation 4. electronic field non-linearity from heating, resistance, efficientcy losses, oversaturation 5. air heating, compression, angry atoms DONT do a good job taking orders when are not happy especially orders to get louder. 6. an increasing percent of the TOTAL sound power is turning into wind (instead of pressure) 7. increasing flex and sympathetic vibrations and or vibration from nearby objects including the ground (which releases air pressure) 8. amperage and electron flow non-linearity 9. with loudspeakers, voice coil and suspension non-linearity 10. sound pressure OUT is proportional to the SQUARE ROOT sound power IN. 11. the universe is in a constant state of "order to disorder" otherwise known as "increasy entropy" or "increasing disorder".This simply means the universe wants everything and its nieghbors to be at or nearly the same: temperature, order, randomness, atomic energy state and of course SOUND PRESSURE LEVEL. As an example, look at the ocean, it so smooth for thousands and thousands of miles, it's totally flat except for maybe 5 or 10 foot waves. 5 feet divided by 3000 miles is almost zero, which means it is very "smooth". 12. the nieghbor part of reason 11. Atoms are like us. This means every atom wants a good neighbor atom, or at least a nieghbor that is like them: so a "sleeping" atom wants a "sleeping" atom nieghbor, an atom at 130 db wants a nieghbor atom at 130 db, not at 10 db and definitely not 160 db, and a 165 db atom wants a 165 db nieghbor atom or maybe 164.9 db or 165.1 db BECAUSE THEY HAVE MORE IN COMMON. Separating atoms with walls of steel or bulletproof glass doesnt really change this need of atoms, just like you still would not like to live next door to a drug dealer or a loud construction site, even with a steel wall fence in between you. |
Gold Member Username: StnorrisDavenport, IA US Post Number: 1570 Registered: Apr-06 | why is meade hitting like 157 - 159s with btls and mts, but theres videos of solo xs hitting 167 - 169.... |
Gold Member Username: Extrmndor3Fack you taco vendor , fack drivin... Fakin crybaby Post Number: 2533 Registered: Feb-06 | is all in the car and system system=car+amp+charging power+sub+box the solo i htink ur thinkin of a crx with a solo x well the crx are the easiest cars to get loud a single dd 9915 will get u 170 db's if u know how to install them meade is going for sq mainly and histruck is a suburban means it has alooot of room inside and the sounds pressure get lost inthere compare the spac eon his truck on the space of the crx's??? theres your answer |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 987 Registered: Jan-06 | the pics and vid are shweeeet |
Silver Member Username: Jenifer_contrerasPIMP Member, Yokosuka, Ka... Post Number: 904 Registered: Jul-06 | wow what a nice tweeter! LOL |
Gold Member Username: B101USA Post Number: 3735 Registered: Sep-05 | r u talkin about burps? then i predict u do mid 40s... bassrace I predict u do mid 30s.... u havent been specific as of, what equipment, wires, and batts ur using... also why are u guys comparing a street beater VS a extreme vehile? |
Gold Member Username: Basshead86OG eCoustics Member Post Number: 8534 Registered: Aug-05 | b/c it is lilrob. he is using 6 Phoenix Gold Octane R Z rated subs. |
Gold Member Username: 54danny54Betsy layne, Kentucky..GO... \blink, red,... Post Number: 2861 Registered: Nov-04 | aye little robert...how do those compare to the PG Xenon subs? |
Silver Member Username: Tremor1127Post Number: 430 Registered: Aug-06 | not even a comparison, the octanes will rip you apart... |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1007 Registered: Jan-06 | are these the ones, damn low price if you ask me http://stores.channeladvisor.com/thedeepdiscount/items/item.aspx?itemid=2285588 |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1008 Registered: Jan-06 | can $35 subs actually get that loud? |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1009 Registered: Jan-06 | or better yet...which one is it on this site, i might want some of these puppies http://www.onlinecarstereo.com/CarAudio/ProductList.aspx?CategoryID=18&Manufactu rerID=650 |
Silver Member Username: Jenifer_contrerasPIMP Member, Yokosuka, Ka... Post Number: 941 Registered: Jul-06 | it's depend of the AMP and the music what you play on it! |
Silver Member Username: Kaos15thPost Number: 279 Registered: Mar-05 | eh....ive seen people in comps whit crappier subs hit high numbers so its possible |
Gold Member Username: Tdeaton1021Near Tampa, Florida USA Post Number: 3245 Registered: Sep-04 | Steve meade doesnt hit 168s and stufff because he isnt a modified vehicle, no wall, and isnt tuned just below his trucks res freq. But he is still the loudest truck in the world in his category... so that says alot. |
Gold Member Username: BestmankindFi AudioBTL Post Number: 7026 Registered: Oct-05 | steve meade has the loudest street beater right now. |
Gold Member Username: RedlinerWilmington, Ma Post Number: 2868 Registered: Jun-05 | "well the crx are the easiest cars to get loud" i know im probably gonna get some people arguing with me over this but. crx's are actually very hard to get loud a lot of people have trouble geatting them loud. But the fact is once u get them figured out u have it and they get very loud. |
Gold Member Username: Extrmndor3Fack you taco vendor , fack drivin... Fakin crybaby Post Number: 2541 Registered: Feb-06 | yeah thedeepdiscount got them very cheap but check the shippin is like 50 bucks for a single 12 for ground and they dont discount if u buy another sub compared to the xenon they are very good subs awesome sq and get loud pretty good well the subs i think they are pretty cheap and they worth the money well if u can buy one so u can see for yourself |
Gold Member Username: DrivingrecklessTREO, USA Post Number: 2226 Registered: Apr-06 | LOL lil rob is still cryin bout it |
Gold Member Username: Extrmndor3Fack you taco vendor , fack drivin... Fakin crybaby Post Number: 2542 Registered: Feb-06 | oh |
Gold Member Username: 54danny54Betsy layne, Kentucky..GO... \blink, red,... Post Number: 2863 Registered: Nov-04 | lilrob man drive down here to KY and let me hear em lol. jk il try to find a shop with em round here |
Gold Member Username: RedlinerWilmington, Ma Post Number: 2876 Registered: Jun-05 | no one gonna comment on my crx post wow thats a first lol was waiting to come back and get flamed |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3778 Registered: Mar-04 | People say CRX's are easy to get loud because they dont really realize what goes into getting a vehicle truly LOUD. They just go to a comp and see 2 12's in a CRX w/ 2500w do ~155 and automaticly say...'that vehicle is easy to get loud'. In reality, no vehicle is 'easy' to get loud. It takes work...always. It is relitivly easy to get a CRX over 150db, but once you hit the 152db mark...its gets harder and harder w/ every tenth you gain. Mini-trucks and CRX's do have the upperhand compared to most other vehicles on the road though (in the US). Infact, mini-truck may actually have a small advantage over CRX's. I you have never built a true 150dB system...you dont realize what goes into gettin into the 150's. I have all the room in the world in my truck to do 3 15's and put a tool-box in the back w/ batts and amps, but I like the idea of getting LOUD w/ 1 15" and 1 amp |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1028 Registered: Jan-06 | and he's gonna do it to...of course a DD is one monster of a sub. |
Silver Member Username: Th3pwn3rChicago, Illinois U.S.A Post Number: 740 Registered: Jul-06 | "he solo i htink ur thinkin of a crx with a solo x well the crx are the easiest cars to get loud a single dd 9915 will get u 170 db's" Hey lilrob do you have any links or proof of this,I'm not saying it hasn't been done but I'd just like to see who and how they did it. |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3779 Registered: Mar-04 | Alan Dante did 177.8dB w/ 1 dd9515 in his Extreme-1 car at dBdrag finals this year. |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1030 Registered: Jan-06 | omg...is there a video of that? I would love to see it. |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1032 Registered: Jan-06 | or at least a link |
Gold Member Username: SouthernrebelMonroe, Louisiana DD 9515d~~]... Post Number: 3780 Registered: Mar-04 | check over on termpro.com it was in an extreme vehicle...concrete, bullet proof glass, etc... |
Gold Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 1034 Registered: Jan-06 | cant find anything there...glad to see i aint the only one up this late |
Silver Member Username: RenegadesrunLafayette, IN US Post Number: 501 Registered: Oct-04 | Getting our Rex was neither "easy" or cheap. 2 12's - 2k (90 lbs a piece..not some swapmeet bullsh!t) 4 memphis 4 kw's - 4k (at least) deck - 400 wire - 400 deadening - 400 alt - 400 batt 300 Hours? 5 ppl 2 months, with at least 2 working on it every single day. Result? 154.3 at finals. 155.6 at home. The Panda would be the "easiest", but not available here in the states. |
Gold Member Username: RedlinerWilmington, Ma Post Number: 2878 Registered: Jun-05 | ya ive seen a couple people on diffrent forums saying how it sucks getting them loud but marshall i know that lol |
