Help
Username: Skater4life69182
Michigan USA
I just went out and bought 12 gauge wire for my amp.....it worked fine with 18 gauge.....my two lightning audio subs cant be powered at the same time.....i can only power one at a time....im running a sony explode amp....its a 444 watt.....my amp shuts off when i attach both....and i have to turn my amp down to make one of my subs sound right....and then i cant turn it up to what i normally have it
Username: Logan__tille
Hamilton, Indiana United states
Post Number: 1769
whats the voice coil config on the subs and does the amp put out 444watts at 2 or 1ohm?
Michigan USA
ok its only 80 watts per speaker....and its pushing 4 ohm's i guess that what i found....and i dont know much about the config of the subs....i know its got a 2" voice coil and its a single voice coil
Username: Tjmutlow
Post Number: 2958
because ohm load is not correct if your bridging that amp with both subs.
Michigan USA
i did that.....it still shut off.....but oh well im getting a depth charge amp today its 500 watt
