Help modding the arsenal box
Username: Grebnereon
Post Number: 188
my current box is sealed, it is about as big as a box possibly can be to fit in my car(2cu ft per chamber NET), so i want to port it using those tubes,cant remember what theyre called....anyway, could anyone tell me what i need to do to my box to port it at 32Hz??? and maybe where i can buy the tubes or whatever
Username: Frkkevin
Lake Worth, Texas US
Post Number: 851
first off what size aresenals are we talking about? what are the dimensions of the box?
Post Number: 189
12" arsenals and the box is 30"across, 22 1/4 deep and 14 tall....inner dementions are 28.5Across,20Deep, and 12.5Tall=2.061 cubic ft per chamber, not including displacement, also the front is double baffle
Post Number: 190
i know i want to put the tubes in the sides of the box (1 going to each chamber),i think that would be the best place but behind the subs, so as to not hit them, i have about 14 or so inches to work with there, but i need to what size of tubes to use to acheive 32Hz and also where i can get the tubes
