Silver Member Username: Mr_keboAlbertville, Al USA Post Number: 505 Registered: Nov-04 | Well i need 2 10" SQ Subs for under 500 dollars that can be ran by an eD NINe.1 amp. The box for them is 1.85 gross cu ft. |
Gold Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 1775 Registered: Apr-06 | https://ssl.perfora.net/www.ficaraudio.com/sess/utn;jsessionid=154511b48e58fb1/shopdata/0030_SSD/product_overview.shopscript 2 10" FI SSD should do fine^^^ or http://www.ascendantaudio.com/arsenal10specs.html 2 10" AA arsenals or http://tcsounds.com/tc2000.htm 2 10" TC tc-2000 |
Gold Member Username: Basshead86Google is your Friend, FL Post Number: 6064 Registered: Aug-05 | SSD's arent SQ subs....their SQ is in between the SE and SX, accodring to scott. kinda like an affordable streat beater. |
Gold Member Username: JakeyplaysbassSt. Louis, MO Post Number: 1498 Registered: Jul-05 | Boston G5 10s http://cgi.ebay.com/2-Boston-Acoustics-G510-4-10-SVC-Subwoofers-1800-Watt_W0QQit emZ140029786218QQihZ004QQcategoryZ3291QQssPageNameZWDVWQQrdZ1QQcmdZViewItem run it at 2ohm, in a smaller sealed box and they will sound amazing. |
Silver Member Username: DelsolePost Number: 908 Registered: Feb-05 | mabe to w6v2's |
Silver Member Username: UdaiPost Number: 198 Registered: Dec-04 | 2 Diamond audio d6s should be perfect for you. I assume the nine1 is stable at @ 1ohm(1200 watts). The d6s are 600w rms a piece, and will run you about 550 shipped from woofersetc. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 9147 Registered: Jul-05 | ^^eww...those subs are not that great... i like the G5 w6v2 rlp Idq's crystal comps all of which should get the job done very well |
Bronze Member Username: LikeapumaWashington/Utah Post Number: 43 Registered: Aug-06 | There's a new procast 10 on Ebay right now for 100 shipped. My procast 12 has amazing sound quality, and gets very loud. -C |
Bronze Member Username: LikeapumaWashington/Utah Post Number: 44 Registered: Aug-06 | ^^ Mmats Procast, by the way -C |
