Class A/B amps
Username: Esonurchess
Albany, Ga Usa
Post Number: 31
trying to settle on an amp for 2 dd9515 4 ohm subs. i was told class a/b amps would be best suited for setup because they are better for SQ? with that being said what amps do you guys recommend?
Username: Thomas_g
NM
Post Number: 1767
I dont know bout the whole "class a/b amps are best for sq" thing, but i would try for a class d amp because they dont get as hot.
Username: Southernrebel
Monroe, Louisiana USA
Post Number: 3321
go w/ a clas-D amp...they are alot more efficient. and w/ the amount of power you would want to run on 2 9515's, you are gonna what efficient amps.
Username: Kaerfpl
Spencerport, NY USA
Post Number: 402
^^^agreed. Class A/B amps I would say are more for speakers and class D are better suited for subwoofers. Overall, i'd personally go with class D amps for everything.
Albany, Ga Usa
Post Number: 32
gotcha.. thanks for the feedback
Username: Juliob
Santo DomingoDominican Re...
Post Number: 2301
class D for subs all the way
Username: Basshead86
Google is your Friend, FL
Post Number: 5933
wow, then your system would sound like sh1t!!!!! lol
and don't say "well i would have fullrange Zapco amps"...b/c those cost and arm and a leg
Class D amps were produced for high power applications, thats it.
you can argue technical specs alllll day, but i have heard subs with Class D amps and Class A/b amps....and the class a/b amps just sound cleaner to me...not as sloopy(might be a dampening thing) and not as boomy(might be a BB thing) but overall....they just sound cleaner.
my whole system is run on Class a/b amps...and i can't complain about not having enough power. lol
Post Number: 5934
i agree with marshall though, for the kind of power yu are looking for 4-6kw, class D's will be your best bet.:-)
Los Angeles, CA USA
Post Number: 5507
can someone explain to me why class ab amp would have better sq than the class D on subs?
most likely you are not going to be playing freq above 90-100hz on your sub so what would a person benefit from a class ab?
Username: Naledge503
Portland, Oregon U.S.
Post Number: 222
Chad read this. Scroll down and it talks about the different classes of amps.
http://wickedcases.com/caraudio/ampspecs.html
Username: Alias747
MN
Post Number: 1300
"you can argue technical specs alllll day, but i have heard subs with Class D amps and Class A/b amps....and the class a/b amps just sound cleaner to me...not as sloopy"
Argue that one with Richard Clark Muddy! :-)
Sloopy lol
Username: Juliob
Post Number: 2310
you're gonna put more current though...
Post Number: 5956
w/e dude.
it doesn't matter....it more than likely is ALL install and user knowledge. but if you used a class D on components...it wouldn't sound good...and simply knowing that, i can't play my subs with it even though i can't hear the distortion at that low of a freq. CHAD!....
Post Number: 5957
hahahahaha sloopy...didn't catch that until now.:-):-)
Username: Glasswolf
Wisteria, Lane USA
Post Number: 11604
I use all class AB amps in my system, but really you won't her a difference with a class D amp on subs, if you stay below clipping. A class D amp will run cooler and mroe efficiently as well.
use class D for subs, class AB for full range.
Username: Buloi123
Philippines
Post Number: 9
"A class D amp will run cooler and mroe efficiently as well.
use class D for subs, class AB for full range."
-AGREE-
