New member Username: Avirex64Post Number: 1 Registered: Sep-06 | I got 2 mtx dual 4 voice coil 15 inch 8500 subs and got a hifonics BXI1606D mono block amp 1100 watts rms at 2ohms. My friend told me I should hook the subs up parallel using this amp because the subs rms is 1200 watts when ran together. Is that correct? I dont really know to much about amps. If anyone knows what i should do please let me know |
Silver Member Username: Andysd03Post Number: 418 Registered: Jan-06 | your amp is only 2 ohm stable and u got 2 dual 4 ohms which equals 1 ohm in parallel your gona have to hook them up in series or your amp is gona have problems!!! you should of goten 2 dual 2 ohms subs and have had them hooked up in series which would equal 2 ohms perfect match for your amp you are rather gona need to switch your subs or get a 1 ohm stable mono amo 1500wattrms the orion2500d shoould be perfect match or that one mtx amplifer that does 1500wattrms at 1 ohm will work dont listen to your friend hes wrong |
Gold Member Username: Mikechec9Post Number: 2451 Registered: May-05 | The amp is one ohm stable @1600w. Your friend was correct. |
Gold Member Username: Mikechec9Post Number: 2452 Registered: May-05 | http://mobile.jlaudio.com/support_pages.php?page_id=161 |
Silver Member Username: Tremor1127Post Number: 172 Registered: Aug-06 | ya, its 1 ohm stable, run them like this... http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html?subs =2&impedance=DVC4x2 |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 511 Registered: Jan-06 | BURP!!! |
Silver Member Username: TweekerPost Number: 476 Registered: May-06 | Mr. michael cheatham this is a warning you will be banned if you continue |
New member Username: Avirex64Post Number: 4 Registered: Sep-06 | ok but my subs are only 1200 watt rms so wouldnt this amp blow them |
Silver Member Username: Tremor1127Post Number: 175 Registered: Aug-06 | 1200 for the pair? if so, no, it wont blow them... you wont see the full 1600 watts, you will be giving them about 700-750 apiece... |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 512 Registered: Jan-06 | hold on..I dont want to be banned. but since when is a silver member also an admin? I got more posts than u tweeker. anyways....I apologize. just having a little fun here. |
Silver Member Username: TweekerPost Number: 478 Registered: May-06 | LOL its cool man i was just messing with ya while youre drunk![]() |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 513 Registered: Jan-06 | hold on tweeker....how u change your name like that???? |
Silver Member Username: TweekerPost Number: 480 Registered: May-06 | top left side corner fin edit profile type in your user name pasword the chane your name and save profile changes and youre done lol |
Silver Member Username: Tremor1127Post Number: 176 Registered: Aug-06 | awesome, ive been wishing i could change my name... |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 514 Registered: Jan-06 | DID IT WORK? DAMN CANT TYPW WHEN DRUNK...LOL |
Silver Member Username: TweekerPost Number: 484 Registered: May-06 | yep it worked lol i cant believe you guys dint know how to change it lol |
Silver Member Username: Tremor1127Post Number: 178 Registered: Aug-06 | im not real smart... |
New member Username: Avirex64Post Number: 5 Registered: Sep-06 | yes tha pair is 1200 watt rms and the amp is 1600 watt rms so it wont do any damage to the subs or amps? i thought u wasnt supposed to put more wattage to the subs than the rms?????????? |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 515 Registered: Jan-06 | BUUUURRRRP AGAIN,, bedtime for me, see yall later |
Silver Member Username: Tremor1127Post Number: 179 Registered: Aug-06 | 100 watts over rms isnt a big deal, that amp wont put out the full 1600 watts and plus, you wont kill a pair of mtx 8500s with 1500 watts... they make a brutus 1200 watt if your scared... |
New member Username: Avirex64Post Number: 6 Registered: Sep-06 | oh ok, do you think this amp will put them to the max? |
