I need box ideas
Username: Slickmanarino
i have 4 of the new 15L7 and 2 memphis mojo amps they are 2400 watts rms in a wall in a 91 cadillac sedan deville. box now has approximatly 3 cubic ft per sub tuned at 36 hertz. i hit 146.7db at 46 hertz on the termlab mics at a sanctioned db drag ss 3,4. luckly not that many people showed up so i won my class but there were 2 sub cars hitting the same range and louder with stock altinators, no extra power upgrade as extensive as mine. any ideas ast how i can redo my box. any ideas greatly appreciated.
this is my lay out:
Pioneer Premier 860
Alpine V12 345
Diamond Audio D6 5 1/4 components
Diamond Audio D6 6 1/2 components
Kicker 4 06s15L7d2
Memphis Audio 2 mojo's
stinger 290 amp alt
stinger dry cell deep cycle
die hard gold under hood
1/0 guage wire w/upgraded factory wiring to 1/0
Username: Basshead86
Google is your Friend, FL
Post Number: 5784
NICE HU:-)
and how is that Stinger Alt. working out for ya...those things are MEAT. lol
Username: James1115
Ct
Post Number: 6550
so you are giving each sub 1200 watts? or 2400 between the 4?
1200 each and i love the stinger alt. i can beat on it all day and my voltage only drops to 12.1 at the lowest.
Pioneer Premier 860
Alpine V12 345
Kicker 4 06s15L7d2
stinger 290 amp alt
please help me out with any ideas on what i can do with a box.
Pioneer Premier 860
Alpine V12 345
Kicker 4 06s15L7d2
stinger 290 amp alt
Post Number: 5785
ok...stop posting your setup now. lol
Post Number: 5786
12.1 is bad....lol
you are at battery voltage at that point man....
my alt when i first got it put in was a 15.2 at idel with the system full tilt.:-)
Post Number: 7
thats when its on all day. when i compete it's always over 15
Post Number: 5787
good.:-)
how much port area does your box have?
and also what is it tuned to?
Post Number: 5788
forget the second question...saw it at the top. lol
Post Number: 8
the top two subs share a 6 cubic ft section and sme with the bottom two. I had my installers build the box when I managed sound waves but we didn't have kicker then but i do know that both ports are tuned to 36 htz and i test it with test tone 46 htz
Post Number: 5790
no....how much port area does the box have?
width x height of the port opening...
Post Number: 9
let me go mesure right now
Post Number: 10
4 1/2 w x 10 h x 12 deep
Post Number: 5793
so the whole box shares one port which is 4.5" wide by 10" high...that is 45sq.in. of port area....
so if your box is 12 cubic feet in volume and your port which is used for all 4 subs is 45sq.in. then your box has 3.75 sq.in. of port per cube....that is your problem. lol
Post Number: 12
no the box is devided 6 ft on top and 6 ft on bottom and a port for each the top and bottom. thank you for your quick response, i have a comp to go to monday so i need to get started tonight on fixing my problem
Post Number: 5796
ok...so then you have 45sqin for each 6 cube section.... that makes 7 sq.in. of port per 6ft section....
i would try more along the lines of 12-15 sq.in. of port per 6 cube section man....i dont think 7 is very much especially for the power you are running and if you are competing....the more port are the better.:-)
Post Number: 15
could yo give me what you think the demensions could be, I was only a sale manager not installer so i need pointed in the right direction. i really cant go any wider then the 4 1/2 but i may be able to go a little taller, please help me figure this out. I would greatly appreciate it.
Post Number: 5798
hmmmmm i would try to shoot for around 85 sq.in. for each 6 cube section.
so try like 5w x 17h
or something to that effect.
Post Number: 5799
then try 4.5w x 19 high...and you will need to increase the port depth as well to keep the same tune....but if you are competing i would try 40hz tune or higher....but try it with the new port are fist with the same tune.
here is a port calculator so you can configure how much deeper the port will need to be in a 6 cube box with around 85 or so sq.in. of port area for each 6 cube section.
Post Number: 19
do you think that will make a big diference and should i leave it 12" deep and what hz do you think that would be
Post Number: 20
Post Number: 5801
here is the port calculator...
plug in your box size for each section(6 cubes) and the dimensions of the port(to get 85) and what you want the tuning to be and it will spit out a length for your port to acheive that tuning.
http://www.carstereo.com/help/Articles.cfm?id=31
Post Number: 5802
for a 40hz tune with 85sq.in. of port in a 6 cube box...the port will need to be ~14 in. long.:-)
Post Number: 21
what hz should i tune the port at. if i choose 40 then acording to that web sight you showed me i would have to cut the depth of the port from 12" to 7.1 and i could leave the outer hole the same. wich would be nice since its all flush and looks really nice. but what hz do you think would be best for me, and does anyone know the resonance frequency for my 91 caddy sedan deville, if not will that help me choos were to tune my box at.
Post Number: 5808
i would try 40 or hihger.....remember if 40 isn't loud enough...you can always cut more off....but you will have to make a new one to add it back...
shoot for like 45 see where that gets you.
Post Number: 30
any body else have some idea's
