Cerwin Vega help
Username: Bhupz
Hey whats up i drive a 300c and i bought um some lazers subs they were 1600 watts and yea i havd 2 of those and i had a lanzer 2400 watt amp umm i dont no much umm the subs got messed so iended up buying 2 V MAX 12 Cerwin VEga 600 watt rms and yea i dont know what amp to get cuz i dont want to use the other amp cuz its garbage.... can u help me with what amp i should use... 2 12" cerwin vega v max twin illl add a picture as well [IMG]http://i93.photobucket.com/albums/l49/bhupz_2006/Picture1.jpg[/IMG]
I just looked at the amp i have it is a Lanzer Max Pro ST MXA 252
Username: Basshead86
Google is your Friend, FL
Post Number: 5809
i would check out a kicker kx1200.1
jbl1200.1
orion 2400D
check some of those out on ebay....i am not sure of your ohm configuration... so you will need to figure out if they need to be wired to 1 or 4 ohms.
