Best sysrem for a 2003 F-150 EXT Cab
Username: Walkere21
OCALA, FL USA
I have a 2003 F-150 EXt cab with the back seats taken out. I have around $600 to $800 to spend on the subs and amp. I know i dont need much because im inside of a truck. I dont care much about sound quality i only care about PRESSURE. I'm lookin for 15s or 12s. Can anyone reccomend a set-up for me. I really need the help.
Username: Basshead86
Google is your Friend, FL
Post Number: 5026
a fellow Ocalian!!!!!!!
i woould check out the 15" Audioque SD2.5 15's.
they are under 200 a piece and will handle do great with 500-1500wRMS.:-)
Post Number: 5027
i mean to say they will do well with 500-1500wRMS each.
http://www.audioque.com/aq/SD2_5_Series.htm
Post Number: 5028
for amps check out kicker or soundstream on ebay. perhaps an orion as well.
Username: Walkere21
OCALA, FL USA
so 2 of those 15s should get the job done?
Post Number: 5032
heck yeah dude.
and keep you under budget.:-)
where in Ocala do you live, if oyu don't mind.
and have you ever been to Audionutz? when it was open...
Username: Riskyb
Post Number: 135
2 of these
http://cgi.ebay.com/DIAMOND-AUDIO-D615D4-SUBWOOFER-15-SUB-DVC-WOOFER-NEW-06_W0QQ itemZ270023796259QQihZ017QQcategoryZ18804QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Find an amp that will do 1500 watts rms and your set.
