New member Username: SheaqybonezPost Number: 1 Registered: Aug-06 | hey i just got 2 alpine 12' type r's 2005 i don't know much about systems and i wanna know any suggestions on an amp or nethiung i don't need insane bass i just don't wanna blow em. alrite thanks |
Gold Member Username: Dustin3Tigard, OR U.S. Post Number: 3201 Registered: Oct-05 | MB Quart Raa1000 |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 748 Registered: Feb-06 | whats the voice coil config? |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4964 Registered: Oct-05 | i hope you got the dual 4 ohm. many amps you can use if you did. kicker kx1200.1 orion 1200d jl audio 1000/1 hifonics bx1500D soundstream PCA1000D |
New member Username: SheaqybonezPost Number: 2 Registered: Aug-06 | they are SWR1242D ALPINE 12"2005 ALPINE SWR-1242D Type R 12" DVC SUBWOOFER FEATURES: Impedance 4 + 4 Ohms Dual Voice Coil: Power Handling: 500 watts RMS, 1500 watts peak Kevlar reinforced pulp Rubber Surround Material Custom cast aluminum frame with integrated perimeter venting and heat transfer plate Frequency Response: 24 Hz - 500 Hz Sensitivity: 87 dB Mounting Depth: 8" that all the info on it. if that helps at all, i've been tryin to see what everyone sez aboutti cuz i dont knwo nethign about it.. ad its goin in a ported box. my friends givin to me to use. |
Gold Member Username: James1115Ct Post Number: 6411 Registered: Dec-04 | go with Chad's reccomendations minus the Hifonic's |
Gold Member Username: James1115Ct Post Number: 6413 Registered: Dec-04 | bump dammit |
New member Username: SheaqybonezPost Number: 3 Registered: Aug-06 | alrite ima tryin and find some of these amps and see what werks thank you! |
Gold Member Username: CtmikeCt. Post Number: 1502 Registered: Feb-06 | get this kicker and you'll be happy: http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/1570443/vpcsid/0 /SFV/30046 |
Bronze Member Username: Dlenz4437Post Number: 63 Registered: Mar-06 | chad dont you think a 1000/1 is a little expensive for 2 type r's |
Silver Member Username: AdddisorderWest palm, Florida Post Number: 667 Registered: Jan-06 | haha^^ but it would work |
Gold Member Username: RzarectorCoquitlam, Bc Canada Post Number: 1255 Registered: Dec-04 | nothing wrong with having a good amp... |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2044 Registered: Dec-05 | yeah... quality is there and why the hifonics can't be there... it will do 1000w rms + so what's the deal... hehee yeah he can get better |
New member Username: SheaqybonezPost Number: 4 Registered: Aug-06 | yeah my friend is gonna lend me his 1200 watt amp til he gets his car back the box im gettin off a friend is ported.. does it really matter how the box is? will that kill my speakers or anything like that. and .. so i could run the 1200 watt amp? |
Silver Member Username: Scott_debakerPittsburgh, P.A. U.S.A. Post Number: 676 Registered: Feb-06 | orion 2500 hehe |
Gold Member Username: RovinTrinidad & T... Post Number: 8961 Registered: Jul-05 | post some box details & whats ur budget 4 an amp ....... |
New member Username: SheaqybonezPost Number: 6 Registered: Aug-06 | i'll get a pic up on here. soon of the box. i guess some kid made it wins comps. but it wasn't made specific for my subs. but its ported i'll have a pic up soon. i guess i wanna pay 200 bux at most but if i really have to and its worth it i'll pay more for an amp |
Silver Member Username: Rob_pregRoyal oak, Michigan United states Post Number: 546 Registered: Sep-05 | $300-350 is more realistic for a good 1000-1200w rms amp. for 200 bucks, you MIGHT be able to find something good thats used on ebay, or a pretty low quality new amp. i wouldnt spend less than 300 personally for that kind of power |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2086 Registered: Dec-05 | i'd get one of those... they're for around 210 shipped or maybe less... See if you can get the 1800d (newer version) |
New member Username: SheaqybonezPost Number: 7 Registered: Aug-06 | MA AUDIO HK1000D AMPLIFIER 1000 watt RMS Digital Class-X Mobo-Block Amplifier what about this amp^? for both my subs? will this werk? |
New member Username: Smmackas2004Post Number: 2 Registered: Aug-06 | what ever you do dont deal with hi-fi sound connection they screwed me !! they dont answer the phone when you call then you dont get you complete order! dont belive me check it out at http://www.epinions.com/content_230442569348 |
New member Username: Smmackas2004Post Number: 3 Registered: Aug-06 | i am a autherized dealer for Diamond Audio,Kenwood and Pioneer if you have any questions or would like some pricing please feel free to contact me and we can go over a few things to see if i could help you out . I have 2,4 channel or class D 1000.1-1600.1 amps in stock. |
New member Username: SheaqybonezPost Number: 9 Registered: Aug-06 | im getitn this stuff on ebay and i already have a personal dealer neways. i jsut need help guy not. that and ne1 tell about teh channels that amp ^ i asked about up there. the ma audio one its mono or something whats up the channels? |
New member Username: Smmackas2004Post Number: 7 Registered: Aug-06 | the ma audio is a class d mono amp. if it has two speaker connections it divides the power inside the amp to power two subs. but it is a mono amp . RMS Power @ 14.4V 400W @ 4 Ohm 500W @ 2 Ohm 800W @ 1 Ohm RMS Power @ 17.0V 500W@ 4 Ohm 800W@ 2 Ohm 1000W @ 1 Ohm and wiried at 4ohms you will get 500watts at 17 volts supplyed to it or if you supply 14.4 volts to it you will get 400 watts out of it . Not only that but ebay dont offer a warenty. hope this helped. |
Gold Member Username: CtmikeCt. Post Number: 1528 Registered: Feb-06 | don't get that ma audio amp. when is your amp ever going to see 17v's? and i ordered my kicker 1200.1 off hifi, got it in 5 days, no problem at all. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 2092 Registered: Dec-05 | forget about MA... best amp for the budget would be PA a1000db, lanzar vibe 1200d/1800d, hifonics 1206d or soundstream pca 1000d. there's a line very cheap from soundstream, see if you can get the pic 1400.1 |
