Like
My neighbor mess-up on his box..
Username: Dustin3
Tigard, OR U.S.
Post Number: 3267
He made a dual chamber box for 2 12's, and the port was supposed ot be tuned to 32 hz. well, the port is supposed to be 1.75" in width, and it is that, but then when the port makes the L shape to the left, for the left sub, and to the right for the right sub, he put the mdf on the wrong side, so that portion is 2.5" in width
how much of a diff will this be in tuning about?
Username: Naledge503
Portland, Oregon U.S.
Post Number: 168
we all know that is your box. lol
Username: Rovin
Trinidad & T...
Post Number: 8941
yea BM3 u big liar just say its ur box u screwed up - lol ......
Username: Adddisorder
West palm, Florida
Post Number: 675
haha i dont know what the tuning comes out to be but i wouldnt run that with each sub tuned different
Username: Dustin3
Tigard, OR U.S.
Post Number: 3269
lol. no. its not my box. if it wuz my box i woulodnt care cause i have only made 2, so i wouldn't lie.
but no, each side is exctly the same. one chamber is the same as the other. he made it so the biginning of the port is 1.75" across, and then when it goes to the L, is 2.5" across. what would that tune out to be, if anyone knows.
and no, it isnt my box , i'll have pics of my new one in a couple days when i carpet it :-)
West palm, Florida
Post Number: 678
im pretty sure it would be lower
Username: Dustin3
Tigard, OR U.S.
Post Number: 3270
like 30 hz?
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1264
how long is the secion with the bigger port and how long is the section with the smaller.. it will make the tuning higher though.. a bigger port has to be longer to get a lower tune
Username: Thomas_g
NM
Post Number: 1613
If the port gets wider then wouldnt that mean its tuned higher???? Unless u increase the length also....
Username: Dustin3
Tigard, OR U.S.
Post Number: 3275
i already said.
the beginnin of port = 1.75"
and then when it goes off to the L shape its 2.5" in width..
he wanted it tuned to 32 hz, which is why 1.75" is supposed to be the width.
so what would the tuniing be around?
Username: Justblaze
St.Louis, MO USA
Post Number: 131
i dont have a clue about the tuning but i think that will get a lot of port noise.
West palm, Florida
Post Number: 693
this is confusing me now, maybe a diagram would be easyer to get the picture
Username: Frkkevin
Lake Worth, Texas US
Post Number: 501
just have him put another piece of mdf on the other side of that port side to make the port width 1.75" the whole length. The only thing that would happen is that one piece he put in that was in the wrong spot would take up a little volume but not enough to effect the tuning frequency by much.
Username: Frkkevin
Post Number: 503
just have him put another piece of mdf on the other side of that port side to make the port width 1.75" the whole length. The only thing that would happen is that one piece he put in that was in the wrong spot would take up a little volume but not enough to effect the tuning frequency by much. That and one port wall would be twice as thick... oh well
Username: Dustin3
Tigard, OR U.S.
Post Number: 3283
i know. i was JW if anyone knew what the tuning would be
Username: Frkkevin
Post Number: 505
depending on the displacement of that piece of wood you should not see more than 1hz lower so somewhere in between 31-32hz give neverything was built to those specs to begin with
Username: Rzarector
Post Number: 1270
not the width bassman the length of the 1.75 section and the length of the 2.5 section
Username: Dustin3
Tigard, OR U.S.
Post Number: 3286
idont know the length exactley. I would have to ask him.
Username: Rzarector
Post Number: 1275
that will depend on how much the tune changes.. it will definately be a higher tune though.. and yeh you could add a peice to the port.. unless of course the box is all put together
Username: Dustin3
Tigard, OR U.S.
Post Number: 3287
how much higher you think? like 34? so like 2hz higher
Username: Rzarector
Post Number: 1283
like i said it depends if the thicker section is quite long it will have more of an effect
Facebook
Shop Related Deals
Directory
