Amp question cont...
Username: Thumping_corsica
Saginaw, miUnitd states
Post Number: 8
my budget on an amp for my 2 type r 10's(ported boxes, 4 ohm dvc's) would be about 300 bucks (i can use ebay to) thx a lot..
p.s.- would 5 gauge power cable be big enough?
Username: Basshead86
Google is your Friend, FL
Post Number: 4703
wrong section.
try Kicker.
they are relatively cheap on ebay.
look for a kx1200.1
Post Number: 10
ok thx a lot...
Username: James1115
Ct
Post Number: 6362
good call on the kicker if you can find it for that price. I am sure you can on ebay.
