Silver Member Username: Adam_sWisconsin USA Post Number: 146 Registered: Aug-04 | Well it started off as my first sub box project....but it really started to suck...first of all the box was too big to fit through the trunk opening. So the liquid nails had already started to dry by the time I went to fit it. So I had to take the Jigsaw and cut the front off the box...Well I got it off and somehow got the box into the trunk...then I had the problem of getting the front back on and mounting the sub....well with a lot more work she finally is in there...takes up a lot of room....but hopefully tommorrow I can enjoy some wonderful music outta her....one good thing about the box is that no one will be able to steal it becuase you cant get the sub or box out...Remember this is my first box...I learned a lot from it so take it easy on me....lol |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 564 Registered: Aug-05 | wow thats tight... i mean the fit, thats tight. it looks good though... u just told us u used a jigsaw, so any one could use 1 to get ur sub. |
Silver Member Username: Adam_sWisconsin USA Post Number: 147 Registered: Aug-04 | haha....well if someone is going to break into my car and use a jigsaw to cut out the sub....well good luck to them...lol...and now that its in there its really hard to get to the back of the box....but yeah its really a tight fit....I cant wait to listen to it....its tuned to 31hz...now I just gotta order my new amp when I get some extra cash.. |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4747 Registered: Oct-05 | is your car a hatchback? if not why do you have your sub firing up? it usually sounds better when you have the sub firing toward the rear in a trunk car. |
Silver Member Username: Adam_sWisconsin USA Post Number: 148 Registered: Aug-04 | no its not....There is some fit issues....But I think tonight or tommorrow im gonna take out the spare tire and try and flip the box so that its firing towards the rear....thats just the only way I could get it in so I left it for now.. |
Silver Member Username: Adam_sWisconsin USA Post Number: 149 Registered: Aug-04 | I just listened to it this morning and wow...It is loud...and that is with a crappy 500 watt audiopipe amp....I cant wait untill I get my cell phone deposit back so I can get my new amp.. |
Gold Member Username: BestmankindLos Angeles, CA USA Post Number: 4756 Registered: Oct-05 | lol how much was your cell phone deposit? glad to hear you are very pleased with it. one thing i hate is to put in hard work and it comes out like sh!t. good job man. |
Silver Member Username: Adam_sWisconsin USA Post Number: 150 Registered: Aug-04 | yeah....i know it doesnt look the best...or fit the best...but its in....and I can look back and be proud because it turned out...sort of....lol..but to me it sounds 100 times better and louder than my old subs....the deposit was 200 but when I get it back ill get interest back too...I am thinking about getting the Hifonics bxi1606d....what do you think about that amp for this sub?? Is it allittle overkill or no?? another amp I was looking at is the kicker 750.1 |
Silver Member Username: Efil4zagginChi Town, IL Cook Post Number: 213 Registered: Dec-05 | dude.....wut kinda sub is that??? |
Silver Member Username: Adam_sWisconsin USA Post Number: 151 Registered: Aug-04 | 15" soundsplinter Rl-p |
Silver Member Username: Adam_sWisconsin USA Post Number: 152 Registered: Aug-04 | bump about the amp |
Gold Member Username: Cenus420 , 420 420 Post Number: 2182 Registered: Jan-05 | what is the VC config on it, and whats the rms rateing, im thinking its dvc4 since the kicker is only 2ohm stable and around 1000wrms, if it was me i'd look into a mtx 1501d amp, 1000wrms@2ohm at 12volts so in a car you will get around 1300-1400wrms from it, they go cheap as h3ll on ebay. and thats a pretty decent box for a first time, are you gonna carpet it? |
Silver Member Username: Adam_sWisconsin USA Post Number: 155 Registered: Aug-04 | umm I would like to carpet it...but there isnt really ne way of getting it out unless I cut it up....so it will prolly remain uncarpeted...maybe I will paint it.. |
