New member Username: SkegPost Number: 8 Registered: Aug-06 | Ok well i posted here a week or 2 ago with a problem with a 2000watt amp i blew it up but got new one and wired my subs in series, my problem is i have 2 visonik subs 1000watt max each a 2000watt max amp 2 chan and im using 2 channels because i have the subs in independant inclosers like its a box with wood in the mid anyway when i turn it up and it gets pumpin on Low pass setting on the amp or i think maybe on full pass also at high levels the subs look like one is sucking in and one is blowing out but id dont do that at lower levels and i checked all wireing in and outside subs and dont see a problem does it just look like this is this a problem or what cuz this makes me like not want to turn up my car "afraid of blowing a sub/amp" thanks for your help -JoN- |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8623 Registered: Jul-05 | they are out of phase |
New member Username: SkegPost Number: 9 Registered: Aug-06 | how i fix? |
New member Username: SkegPost Number: 10 Registered: Aug-06 | How do I fix this and is this ok? I also am missing one screw on each sub cuz i stripped it out and i have a small air leak |
Silver Member Username: WingmanaliveGreensburgh, PA US Post Number: 167 Registered: Jun-06 | ![]() |
Gold Member Username: James1115Ct Post Number: 6159 Registered: Dec-04 | it isnt wired properly, I would fill in the hole with silicone. |
Gold Member Username: James1115Ct Post Number: 6160 Registered: Dec-04 | lol Paul lolol |
Bronze Member Username: SkegPost Number: 11 Registered: Aug-06 | its wired in series i check with tone gen and unhooked the subs un bolted them and check the wiring and its fine i just want to know how to keep them phased at higher bass levels |
Bronze Member Username: SkegPost Number: 14 Registered: Aug-06 | anyone?? please im dieng here lol |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8630 Registered: Jul-05 | go here #31 about half way down the page http://www.bcae1.com/ |
Gold Member Username: James1115Ct Post Number: 6163 Registered: Dec-04 | if they are phased at low level's they are gonna be phased at high level's that doesnt change. You need to reverse the polarity. what amp do you have and what HU do you have? |
Bronze Member Username: SkegPost Number: 15 Registered: Aug-06 | I gotta a JVC touch screen head unit and my amp is the Lanzar VIBE266 2 Channel 2000 Watts High Power MOSFET Amplifier, VIBE-266 head unit is a JVC KD-LHX502 there wired in series and i guess normal to the amp im using both channels |
Bronze Member Username: SkegPost Number: 16 Registered: Aug-06 | well anyone? |
Gold Member Username: James1115Ct Post Number: 6169 Registered: Dec-04 | see if your amp has a phase switch on it. If it does switch it to 180 degres, if not I am sure your HU does. |
Bronze Member Username: SkegPost Number: 17 Registered: Aug-06 | nope the amp dont where would the HU switch be? on the head unit? |
Gold Member Username: James1115Ct Post Number: 6170 Registered: Dec-04 | do you have a sub control boost with that deck? |
Bronze Member Username: SkegPost Number: 18 Registered: Aug-06 | yes i can set for 1 2 or 3 subs |
Bronze Member Username: SkegPost Number: 19 Registered: Aug-06 | should I set it for 1 sub or should i set it for 2 i currently have it set for 2 because i have 2 but the RCA's go into one amp |
Gold Member Username: James1115Ct Post Number: 6171 Registered: Dec-04 | are you running them mono? or stereo? if mono set it for 1 |
Gold Member Username: James1115Ct Post Number: 6172 Registered: Dec-04 | also set it for mono on the HU not stereo |
Bronze Member Username: SkegPost Number: 20 Registered: Aug-06 | its a 2 channel amp so i got it set for 2 should i knock the setting 2 one sub and the will both work and just chek it out or what? |
Bronze Member Username: SkegPost Number: 21 Registered: Aug-06 | ?? |
Gold Member Username: James1115Ct Post Number: 6175 Registered: Dec-04 | why dont you wire your subs mono instead of stereo? |
Bronze Member Username: SkegPost Number: 22 Registered: Aug-06 | to much sork |
Bronze Member Username: SkegPost Number: 23 Registered: Aug-06 | I just really want them in phase |
Gold Member Username: James1115Ct Post Number: 6176 Registered: Dec-04 | are you kidding me? |
Bronze Member Username: SkegPost Number: 25 Registered: Aug-06 | Well I know I can get them to phase just dont know the right way of going about it |
Bronze Member Username: SkegPost Number: 26 Registered: Aug-06 | ?? |
Bronze Member Username: SkegPost Number: 28 Registered: Aug-06 | well what should I do? |
Gold Member Username: James1115Ct Post Number: 6185 Registered: Dec-04 | wire them mono! |
Bronze Member Username: SkegPost Number: 29 Registered: Aug-06 | I dont have the skills my cousin did it for me u think i could get away setting the HU for mono? or somthing |
