New member Username: KingersMelbourne, Victoria Australia Post Number: 1 Registered: Aug-06 | Hey, I need some help, i need to know wat sort of an amp i would need to buy if i wanted to put a Sony Xplode 1000 watt 12 inch sub in my car plus 170 watt 6 inch speakers using a 200 watt Kenwood cd player. I dont really know much about this sort of stuff so any advice would be good, like how many chanels and stuff like that. Thanks heaps |
Silver Member Username: Logan__tilleHamilton, Indiana United states Post Number: 606 Registered: Feb-06 | whats your buget, we can find you a way better system.... |
New member Username: RiskybPost Number: 6 Registered: Feb-06 | I wouldn't reccomend Sony or Kenwood. You can probably find something WAY better for the same or slightly more $. |
New member Username: KingersMelbourne, Victoria Australia Post Number: 6 Registered: Aug-06 | Hey sorry havent been on for ages, i would spend maybe $400-$500 AUD on a sub, speakers and an amp. Then maybe $300 on a head unit. So any advice would be good, thanks |
Gold Member Username: StnorrisIA US Post Number: 1114 Registered: Apr-06 | so are u looking for sq, spl, or sql. and do u want 2 12s, 1 15, 2 10s...... and do u plan on upgrading ur electrical system??? |
New member Username: KingersMelbourne, Victoria Australia Post Number: 7 Registered: Aug-06 | so are u looking for sq, spl, or sql???????????? No idea wat that means, wasnt planning on upgrading my system. And would maybe want 1 12" or 1 15" |
Silver Member Username: ShowridesHartford, CT USA Post Number: 202 Registered: Feb-06 | Sound Quality, Sound Pressure Level, Sound quality level. SPL is plain loud, SQL is loud but sounds good. |
New member Username: KingersMelbourne, Victoria Australia Post Number: 8 Registered: Aug-06 | Thanks well in that case i would be lookin for good sound but i would want it to be loud, i want it to be heard. |
New member Username: KingersMelbourne, Victoria Australia Post Number: 9 Registered: Aug-06 | Just another thing is it any better/helpful to put in a capacitor for the sub??????? |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 1785 Registered: Dec-05 | No cap for subs, check this system... 2 10s AA arsenal, audiobahn a8000V, infinity or PG components, get a 4 channel amp (old school cuz is better) and then you can buy a pioneer HU (very good for the money) |
Gold Member Username: StnorrisIA US Post Number: 1134 Registered: Apr-06 | or u can look at 1 assassin 12, or 1 arsenal 12, and get a pg 400.1 for the assassin, or maybe a kicker kx750 for the arsenal. the arsenal will be alot louder, but the assassin is also a very good sub. http://www.ascendantaudio.com/ |
