Orion HCCA-D5000
Username: Alexv305
Tavernier, FL USA
Post Number: 324
Are the Orion HCCA-D5000's strappable? Like can I hook two up together and get 5000w RMS? And what resistance is that at?
Username: Alexv305
Tavernier, FL USA
Post Number: 330
come on i know somebody has the answer...
Username: Extrmndor3
Chicago, Ill Us
Post Number: 1657
well i think they are strapable just like the 2500d but if ur talkin about the ol skool models i think they are not strapable, if u need 5000 rms at 1 ohm u can get a cheaper amp that will be just like it, a sound stream 6k rms, a earthquaker, atomic 5000.1
Username: Alexv305
Tavernier, FL USA
Post Number: 336
i can get two orions cheaper than one soundstream xx6500d
Username: Usask8er1
Appleton, Wisconsin USA
Post Number: 383
I have a d5000, How would I be able to find out if its strappable? Also what kind of electrical upgrade do you have or are you planning on getting. 5000rms is a huge draw specailly with those amps. And what are you powering?
