Custom sub boxes
Username: Dub_c
Post Number: 132
I have a GMC Sierra X-Cab and all the sub boxes I have seen are .8 cu. ft. Does anyone know where I can buy a sub box like the ones I am looking for(The ones that go under the rear seat) but I want something like 1 cu. ft. If there are not any it cool, just seeing if anyone knows of a website.
Username: Dustin3
Tigard, OR U.S.
Post Number: 2908
make one. i'll help you out
Username: Dustin3
Tigard, OR U.S.
Post Number: 2909
check on the GMC website also, or just look on google or ebay
Username: Riskyb
Post Number: 48
I forget where you can buy them but, they make seat risers that basically raise your backseat a few inches to accomodate larger boxes. I think buying a box like you want will be tough. Best way would be to hire someone to make you one or do a custom one yourself.
Username: Dub_c
Post Number: 134
I have another thread called Best 12" subs out there, if I can get a good loud and clean sub that fits in a .8 selaed box, I'll be good.
Username: Rzarector
Coquitlam, Bc Canada
Post Number: 1244
depends on the mounting depth.. find out what the distance from the baffle to the back of the sub box will be
Username: Dub_c
Post Number: 137
Alright.
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1731
talk to ATF
Username: Dub_c
Post Number: 139
Whos ATF?
