Ported boxes.
Username: Saoxcore
Post Number: 41
hi, im going to be getting an Alpine SWR-1242D - Alpine 12" Type R in a few days. but i need a box. and i sort of want to build my box soon, so i dont have to build it after i get my sub. i know i want it to be ported, but i have no idea how to build a box, and the measurements and stuff.
can someone show me a design and measurements for a good ported box, for my alpine?
Username: Andysd03
Post Number: 343
get a type X they sound way nicer and almost just as loud i heard them both in comparison from one another the type R may be a little boomier but not by much the type X is worth it if its in the right box
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1665
Bro you've never heard another sub???????????
Username: Sploosh56
Ohio
Post Number: 1466
http://www.freewebs.com/wahlsboxes/
Username: Saoxcore
Post Number: 45
lol, i dont want a type x. i want a type r.
and julio, ive heard other subs, but i dont know what that has to do with anything
Username: Saoxcore
Post Number: 46
10 bucks for someone to tell me how to build a box?
Username: Ctmike
Ct.
Post Number: 1231
i think he was saying it to andy f, who you should never listen to.
Username: Saoxcore
Post Number: 48
LOL okay
Username: Saoxcore
Post Number: 51
also, when i get the sub, will the manual have like, a box design?
Username: Ctmike
Ct.
Post Number: 1235
no, i used to have 2 r's. i called alpine and they gave me the exact specs for a ported box, tuned at 32hz.
Username: Saoxcore
Post Number: 53
thats lame.
eh.. how will i know what shape to make the box and stuff from a phone call? LOL
Username: Rovin
Trinidad & T...
Post Number: 8747
http://www.diysubwoofers.org/
input ur own nos here
http://www.subwoofertools.com/forum/ported-box.asp?Ew=25&Eh=14&Dia=6&Xmax=18.2&V d=.071&NumW=1&Vb=1.7&Fb=32&Qts=&Vas=&Fs=&CE=0
Username: Saoxcore
Post Number: 54
^ super confusng
Username: Frkkevin
Denton, Texas US
Post Number: 345
.... are you serious? lol. thats about as easy as it gets. if your that confused build a sealed box or pay for someone to build you a good ported one ...
Los Angeles, CA USA
Post Number: 4632
just buy a prefab box if you aren't too clear about it.
Username: Crayola0
Wisconsin
Post Number: 430
just use this and put ur numbers in.
http://www.subwoofertools.com/forum/ported-box.asp?Ew=15&Eh=16&Dia=6&Xmax=15.5&V d=.13&NumW=1&Vb=2&Fb=35&Qts=&Vas=&Fs=&CE=0
Username: Saoxcore
Post Number: 55
i cant use that. i dont know what a driver displacement or a woofer xmax is. and also, in those pictures, i wouldnt know where to put the sub.
and btw
http://cgi.ebay.com/12-VENTED-PORTED-SUB-WOOFER-SPEAKER-MDF-ENCLOSURE-BOX_W0QQit emZ120013738364QQihZ002QQcategoryZ50568QQrdZ1QQcmdZViewItem
how would that make my sub sound?
Username: Saoxcore
Post Number: 56
?lol
Username: Rovin
Trinidad & T...
Post Number: 8755
contact this ATF guy who builds nice boxes reasonably priced
https://www.ecoustics.com/electronics/forum/car-audio/255597.html
Username: Viperguy
Post Number: 11
Thats a cool site but how accurate is it?
a b, you can get all those specs from alpines site, here is a link to the owners manual.
I will help you, here are the specs you need:
Woofer Qts: .47
Woofer Vas: 1.6
Woofer Fs: 29
Username: Frkkevin
Lake Worth, Texas US
Post Number: 355
That site is actually pretty damn accurate. I used it to build my box for the SX 15". Tuned it to 35hz and on a TL meter my best score was at 45hz which is correct seeing the box peaks out normally 8-10hz higher than what it is tuned to.
Username: Saoxcore
Post Number: 57
thanks viper.
and iwish that maual wasnt PDF. i cant read it :-(
