Silver Member Username: Purplehase_bongBC Canada Post Number: 241 Registered: Apr-04 | im running 2 12" mtx thunder 6000 in Bassworx ported boxes. The boxes are both identical. im hitting about 125db, does that sound right, or sould i be hitting more? there both getting about 250rms each. |
Gold Member Username: StnorrisEldridge, IA US Post Number: 1062 Registered: Apr-06 | ya u should be able to hit quite a bit more than 125 with 500rms... what vehicle do u have, and what amp are u running? |
Silver Member Username: Purplehase_bongBC Canada Post Number: 242 Registered: Apr-04 | i have a lumina sedan, the amp is rockford 401s so i guess im running 400rms in total. |
Silver Member Username: Purplehase_bongBC Canada Post Number: 243 Registered: Apr-04 | hmm, tested my buddies system that has two 2nd gen type R's and he hit 127.5 now im really confused. anyone? |
Silver Member Username: Aman2005Post Number: 262 Registered: May-06 | bump |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 288 Registered: Jan-06 | EWWW...DAMN I have 2-10 inch alphasonik q-reference series subs powered by a 300 watt (220rms) visonik amp, and I can hit 130db. something is wrong there. What kind of meter are you using? |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 289 Registered: Jan-06 | EWWW...DAMN, I have 2-10 inch alphasonik q-reference series subs powered by a 300 watt (220rms) visonik amp, and I can hit 130db. something is wrong there. What kind of meter are you using? |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 290 Registered: Jan-06 | WOOPSIE Sorry aobut the double post |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 291 Registered: Jan-06 | WOOPS, sorry about the double post |
Silver Member Username: Andysd03Post Number: 340 Registered: Jan-06 | 125db is very low especially for MTx I had 2 10" mtx 4500's the lower subs and they hit 132db so something is def wrong in your install i dont have them now i used to a long time ago... u should be at least in the 132 to 135 range i bet they are hooked up in series is why they arnt very loud put them in parallel |
Silver Member Username: AstrosafariDelhi, Ontario Canada Post Number: 547 Registered: Aug-05 | i have a 600 watt 4 channel bridged to my 15" clarion, it doesnt seem all that loud...i havnt had it metered, and im using a sealed box. im sure my amp is giving enough power unless something else is wrong, because i can smeel the coil burn if its played loud for a period of time, with hard bass. |
Silver Member Username: Purplehase_bongBC Canada Post Number: 244 Registered: Apr-04 | dont get me wrong, my subs hit hard. i guess its the crappy db meter im using |
Silver Member Username: Purplehase_bongBC Canada Post Number: 245 Registered: Apr-04 | im using this db meter http://www.sjgreatdeals.com/sisspl1000.html |
Silver Member Username: Wolfman1966WEST MONROE , LOUISIANA USA Post Number: 295 Registered: Jan-06 | He he, I use the same meter, got it from wal-mart. I'm not sure how accurate they are. |
Gold Member Username: Chaunb3400Huntsville, Alabama U.S. Post Number: 8363 Registered: Jul-05 | lol...this whole thread..is funny to me |
Silver Member Username: Purplehase_bongBC Canada Post Number: 246 Registered: Apr-04 | why is it funny? |
