Music From Subs
Username: Thaansweri3
Post Number: 14
Why isn't that sometimes you can hear music from the subs? Like if the amp for the speakers blows a fuse and you can hear music from the subs...
Username: Astrosafari
Delhi, Ontario Canada
Post Number: 504
the subs keep playing, just with speakers the words are alot louder, so you dont notice it from the subs, you some times get a little bit of voclas in the sub...
Username: Illuminator
Post Number: 3694
Probably because you just ruined the amp? :-) It's not common, that's for sure.
Post Number: 509
i can set my amp to how much vocal i want... or i can just turn off the vocal setting and have none...
with my old sht pyramid, it gave voclals like crazy no matter how it was set, and my clarion doesnt give any thing but bass.
Username: Adddisorder
West palm, Florida
Post Number: 503
it depends on your crossover and how good it is
Username: Troy81
Tavernier, Fl Us
Post Number: 836
also depends if its a sub output on your HU or jus an RCA output, and crossover, and amp gain
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1386
hahaha, jexx is right
