Bronze Member Username: Luttrell31Post Number: 18 Registered: Jul-06 | I just got my new car and would like to hook my amps into but i dont think there is a way to without putting a new cd player in(dont want to because of the navigation) or using a line level converter which u dont have much base control with. any suggestions would be helpful. here is a pick of the dash if that helps |
Silver Member Username: KaerfplSpencerport, NY USA Post Number: 185 Registered: Jun-06 | I can't say that ive looked too much into this product but, I think it may help you with your problem...hopefully :/ http://www.alpine-usa.com/en/products/product.php?model=PXE-H650 |
Silver Member Username: KaerfplSpencerport, NY USA Post Number: 186 Registered: Jun-06 | Or you can buy a new nav system! http://www.sonicelectronix.com/item_5250.html |
