Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 496 Registered: Sep-05 | THe speakers thread is dead i need to know if these speakers 5.3" mounting depth JBL speakers would fit in my Honda Civic 2005 doors up front http://www.bestbuy.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0926INGFS10 074535&catid=20114&PCName=# Also these pretty good speakers to runn off a HU right? |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 2047 Registered: Oct-05 | they are good to run off HU. if you have the 4 dr sedan civic, yes they will fit. at least that what www.circuitcity.com says |
Silver Member Username: Teddy21Ann Arbor, MI USA Post Number: 143 Registered: Feb-06 | if they dont fit just cut out some metal...... |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 2072 Registered: Oct-05 | are you worried about mounting depth or diameter |
