Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 345 Registered: Jul-04 | which port is better? and how do u figure out how tall and wide to make ur slot port! and when u make a slot port do u just take a piece of wood and cut it down the the length the port is suppose to be or do u have to buy a plastic piece like round ports?? |
Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 346 Registered: Jul-04 | The box will be for a 15" Mojo |
Gold Member Username: RovinTrinidad & T... Post Number: 8334 Registered: Jul-05 | pipe port takes up the least amt of space of any port designs slot takes most space http://www.the12volt.com/caraudio/boxcalcs.asp http://www.the12volt.com/caraudio/boxcalcs.asp http://www.subwoofertools.com/forum/ported-box.asp ....... |
Gold Member Username: RovinTrinidad & T... Post Number: 8335 Registered: Jul-05 | pipe port takes up the least amt of space of any port designs slot takes most space http://www.the12volt.com/caraudio/boxcalcs.asp http://www.carstereo.com/help/Articles.cfm?id=31 http://www.subwoofertools.com/forum/ported-box.asp ....... |
Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 347 Registered: Jul-04 | ok thanks! how big of a diameter would a round port have to be so that MOJO wouldnt make any port noise? |
Silver Member Username: John_washNashville, Tennessee Post Number: 343 Registered: Dec-05 | i'd go 4" |
Silver Member Username: Yamahabanshee1Paulding, Ohio USA Post Number: 348 Registered: Jul-04 | should i only make one port or what? |
Gold Member Username: RovinTrinidad & T... Post Number: 8353 Registered: Jul-05 | pipe ports ^^^ right ? if u want a bit more spl then yes - i'd say do 2 3" do note with larger diameter pipes the longer it has 2 be so take that onto account when designing ur box' depth ...... |
Silver Member Username: TheweaselSteamboat springs, Colorado U.S. of A Post Number: 509 Registered: Mar-06 | i thought you were getting the sx and your friend halter was getting the mojo? dual identities maybe? jk, lol. https://www.ecoustics.com/electronics/forum/car-audio/244314.html |
