Amp wiring kit?
Username: Gangstafert
Jacksonville, Florida USA
Post Number: 217
what kind of ampkit will i need for two arsneal 12's with a autotek mm1400.1 amp. need help fast. thanx
Username: Rovin
Trinidad & T...
Post Number: 8309
well it depends on the distance of amps from batt use this link
http://www.the12volt.com/info/recwirsz.asp
i would suggest u buy 0g into a distro block with 2 fuses & out into (2) 4g wires .....
Post Number: 219
So could i get all that in a kit i was gonna go knukonceptz and what exactly does the distro block do and is it hard to hook up.thanx
Username: Juliob
Santo DomingoDominican Re...
Post Number: 1032
www.bcae1.com go check
Post Number: 220
Im sorry im a noob and all that was very confusing. Is the install Rovin suggested good and if so can i buy all of that in a kit or not?thanx.
Post Number: 221
Could anyone help me with this. This is my first system and i want it done right and the website givin was sortof confusing. For now i really just need to know what to buy and where to buy it from.Thanx
Post Number: 223
anyone please...
Username: Justblaze
St.Louis, MO USA
Post Number: 21
rovin, why would he need a dist block for one amp?
Post Number: 228
Thats whats confusing me. I need to know what to buy????????
Post Number: 230
anyone???
Username: Dustin3
Tigard, Or U.S.
Post Number: 1970
you dont need a distro block. rovin prolly got confused and thought you were runnin 2 amps.
get a 0 awg amp installation kit. the one at knukonceptz is very very nice but its 80 bucks.
Username: Kravenblood
Ohio
Post Number: 70
you buy a dist block just in case you get another amp you know for your components buy it now so you dont have to later..
Username: Dustin3
Tigard, Or U.S.
Post Number: 1971
not zero. i mean 1 awg.
but you can run the 4 awg wire if you want. that would work fine
Post Number: 231
B told me to get a dist. block too dont you need one if your amp has two power terminals i really dont know they had me so confused earlier. Why is that kit from knukoncepts so expensive is there any cheaper ones? thanx.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1972
for 1400 watts its rec. to use a 2 awg tho so 2 would be ur best bet but 4 if you cant get one :-)
and it doesnt matter if you buy it now or later. it doesnt take long to set up. he never even mentioned anything bout components
Username: Dustin3
Tigard, Or U.S.
Post Number: 1973
i would ask B and rovin why they said that... i'm prolly missin somthin
Post Number: 232
So a 2 gauge amp kit would be best and run it strate through with no dist block. I dont mind buying the 0 gauge kit if thats what i need also will the kit come with a fuse or do i need to buy one? Also i baught the amp from B in that group buy and i thaught i made it clear that i was only wiring one amp and thats where i got confused...
Username: Dustin3
Tigard, Or U.S.
Post Number: 1974
like i said... i would ask B and Rovin why they said that because i dont understand why unless u were gettin another amp...
2 awg would be the best for the amp. ur fuse should be around 175- 200 MAX
Username: Dustin3
Tigard, Or U.S.
Post Number: 1975
they also know alot bout the mean machine amps
Post Number: 233
Bassman i looked up the amp on a couple of sites and it says it has 4 gauge power connectors so maybe thats what B was saying?
Post Number: 234
If that is the case then would that mean the amo has two 4 gauge power connectors then i would need a dist block. Im so d@mn confused...
Username: Dustin3
Tigard, Or U.S.
Post Number: 1991
i dunno, i think that means it can accept 4 awg wiring. i dunno tho... best bet is to ask him (B)-- why he said u need a distro block
Username: Dustin3
Tigard, Or U.S.
Post Number: 1992
maybe ask him in that other forum, the j designs one.
Post Number: 236
Rovin do you know anything about this?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1997
maybe make a new thread in the sub section... where he is most
