I'm a blank slab
Username: Untouchable
I recently got my car. After riding around for a few days, I have realized that I don't like my sound system and I'm ready to yank everything out. My problem is that I don't know ANYTHING about car audio. Needless to say I need help. Is anyone out there willing to help. Keep in my mind I have a budget of about $1000
Username: Dustin3
Tigard, OR U.S.
Post Number: 2478
u have aim?
and is that budget jus for the subs? or the subs and amp?
you needs
subs
amp
box
wirnig
alt? (depends on how much u will be runnin)
Username: Dkchillin
Vermont
Post Number: 199
it sounds like you may also be looking for a new head unit and speakers as well right? Definately spend some time looking around and reading as many posts as you can. There is a lot of good info to be had on this forum, but there's also a lot you should know before you start buying equipment so just take your time. It's hard to make any concrete suggestions, hopefully Dustin can help you out by chatting on AIM because it's hard to be much help in a one way convo like this. If you have more specific questions feel free to post.
My problem is that I have a disc changer. So if I replace my head unit will I have to change the disc changer too?
