Looking for 4" components for good price
Username: Bulldogsm2008
Iowa City, Iowa
Post Number: 249
i need some for my wrangler and i cant fit bigger up front. dont want to spend alot b/c they might get jacked.
Username: Alteraudiousa
Concord
Post Number: 999
YOU CAN SEND ME AN EMAIL AND I'LL SEE WHAT I CAN GET THE CDT CL-41 FOR YOU. JUST MENTION YOU'RE FROM ECOUSTICS IN THE EMAIL.
Username: Theelfkeeper
Stockbridge, GA USA
Post Number: 2444
Rainbow, CDT, MB Quart and Diamond are the only brands i can think of that make good 4 inch component sets.
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7903
i bet they make an adapter so u can fit bigger speaks up there....do a search
Concord
Post Number: 1000
are these on the dash or in the door?
