Bronze Member Username: KaerfplSpencerport, NY USA Post Number: 56 Registered: Jun-06 | Does anyone know the fuse on this amplifier? Or does anyone know what gage of wiring kit to use? Right now, I have 300 watt wiring kit from Sound Quest (don't know what gage it is). Will this wire work with Audiobahn's A2002T? I really don't want to unwire everything but, if I have to, I have to... Im thinking of replacing my MTX with this amp since my MTX is being stupid and not working for some reason. |
Bronze Member Username: KaerfplSpencerport, NY USA Post Number: 58 Registered: Jun-06 | anyone? |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1768 Registered: Oct-05 | i would use 8 or 10 awg wiring kit. pref, 10. 8 would be overkill but its still fine. donmt know the fuse on that anmp... look around on the net |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1769 Registered: Oct-05 | it has 25A x 1 Fuses |
Bronze Member Username: KaerfplSpencerport, NY USA Post Number: 60 Registered: Jun-06 | Ok, my MTX has a 20A x 1 fuse so would switching the amp make a difference in the performance of the wire? This is the wiring kit that I have installed right now but, its blue instead of red. Will this support the Audiobahn A2002T ok? http://cgi.ebay.com/SOUND-QUEST-10-GA-300W-AMP-KIT-TWISTED-RCA-FUSE-HOLDER_W0QQi temZ9742496285QQcategoryZ32808QQcmdZViewItem |
Bronze Member Username: KaerfplSpencerport, NY USA Post Number: 63 Registered: Jun-06 | anybody? |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 415 Registered: Sep-05 | http://cgi.ebay.ca/A8002V-Audiobahn-800W-RMS-2-1-Ch-Intake-Amp-NEW-A8002T_W0QQit emZ9742407856QQihZ008QQcategoryZ48597QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#Shipp ingPayment Is that a good amp?? |
Gold Member Username: Dustin3Tigard, Or U.S. Post Number: 1784 Registered: Oct-05 | joe, yes that would work fine car audio, did u just steal a thread? lol... good amp, i thought u already had a audiobahn amp or somthin |
Silver Member Username: CaraudioToronto, Ontario Canada Post Number: 416 Registered: Sep-05 | noo isnt that the same amp type? I had Lanzar. Im looking to change to Kicker and AUdhioban if i can sell my lanzars. |
