Silver Member Username: Mygame5982H-TOWN, TEXAS US Post Number: 245 Registered: Jan-06 | planet audio P-1250D(200dollars) is it rms 1250watts or peak? plus will it push 2 15" kicker compvrs in a sealed box? if not what amp should i put with the 2 15" kicker compvrs ps...not more then 250 dollars cause i can get a memphis prd1000.1 for 280dollars!! THANKS |
Silver Member Username: Teddy21Ann Arbor, MI USA Post Number: 117 Registered: Feb-06 | go on ebay on type in "bp1200.l" its a jbl amp that pushes out over 1200 watts @ 1 and 2 ohms. and 600 watts @ 4 ohms |
Silver Member Username: Mygame5982H-TOWN, TEXAS US Post Number: 246 Registered: Jan-06 | ia that rms or peak....plus whats the amps of the fuses? and is it better then the planet audio? |
Silver Member Username: Mygame5982H-TOWN, TEXAS US Post Number: 247 Registered: Jan-06 | and what about the planet audio VX1400D? |
Silver Member Username: Teddy21Ann Arbor, MI USA Post Number: 118 Registered: Feb-06 | Planet Audio is just a crappy brand, i doubt that the 1250 is a RMS figure. The Jbl actually puts out more than 1200 watts RMS at 1 and 2 ohms. Now the memphis, Memphis is a good amp but you would have to wire your subs to 1 ohm to get all 1000 watts. Which means you need to get the 4ohm dvc versions of the kicker compvrs. This is the stats for the memphis: RMS Power (W) 300x1 @ 4 ohms / 600x1 @ 2 ohms / 1000x1 @ 1ohm THD @ 4 ohms 0.75% Frequency Response +/- 0.5dB 10Hz - 500Hz Dimensions (in) 10 x 2.5 x 14.00 Optional Remote 16-PRDGC |
Silver Member Username: Mygame5982H-TOWN, TEXAS US Post Number: 248 Registered: Jan-06 | so.....jbl over the planet audio...and memphis over jbl? so which will be better for the price the jbl 1200.1 or the memphis prd1000.1 |
Silver Member Username: Teddy21Ann Arbor, MI USA Post Number: 119 Registered: Feb-06 | look at this http://cgi.ebay.com/MEMPHIS-AUDIO-16-PRD1000-1-LIKE-NEW_W0QQitemZ330000039634QQi hZ014QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem or this http://cgi.ebay.com/JBL-BP1200-1-1200-Watt-Subwoofer-Amplifier_W0QQitemZ97439288 95QQihZ008QQcategoryZ18797QQssPageNameZWDVWQQrdZ1QQcmdZViewItem |
Silver Member Username: Mygame5982H-TOWN, TEXAS US Post Number: 250 Registered: Jan-06 | so which is a better amplifier the memphis prd1000.1 or the jbl1200.1? thanks for your help by the way |
Silver Member Username: Teddy21Ann Arbor, MI USA Post Number: 120 Registered: Feb-06 | i would say the jbl because of the wiring options, you can wire it at 1 or 2 ohms and get full power out of it. With the memphis you have to wire at 1 ohm to get full power. These amps are great but im sure there alot more amps you could find that would work for you. Kicker amps are very good as well as the elemental designs "nine.1". Go to www.dei.com and look at the orion amps. But just remember on wiring of the subs, becuase if you dont get the right voice coil config then you will not be able to get all the power out of the amp. here is a wiring wizard http://www.rockfordfosgate.com/rftech/wiringwizard.asp?WoofQty=2+woofers&WoofImp =Dual+Voice+Coil+-+4+ohms+x+2 |
Gold Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 1099 Registered: Apr-06 | i have a jbl gto1201.1 and i can say they give out wut they say but if u want full power its rated at 14.4 v..... |
Silver Member Username: Teddy21Ann Arbor, MI USA Post Number: 121 Registered: Feb-06 | i think the gto series were rated at 14.4v but the older bp series were rated at 12 volts |
Silver Member Username: Mygame5982H-TOWN, TEXAS US Post Number: 251 Registered: Jan-06 | has anyone heard of this amp? if so what will be better...this one or the memphis!! http://www.mobilesoundworks.com/ProductDetails.asp?ProductCode=raa1000 |
Bronze Member Username: LordvicadinPost Number: 23 Registered: Jun-06 | jbl is better amp than most think.. its made by hafler or crown i think its crown , hafler is fosgates parent company but anyhow. both are good parent brands. ( go with the jbl) |
Silver Member Username: Rick_rossPost Number: 119 Registered: May-06 | the mb quart would be underpowering them a little. this would work perfect if there 4 ohm http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16368 |
Silver Member Username: Mygame5982H-TOWN, TEXAS US Post Number: 258 Registered: Jan-06 | CANT SEE THE LINK!! |
