Treo selection
Username: Splmonster
Nowhere, OH USA
Post Number: 273
i have a friend on a grand prix specific site that has a treo delaer near him, he has about 700 to spend on sub/amp combo whatd be a good choice, thanks
ps no 18's, 15" max
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 1046
i would go for the 12" ssx..at my dealer they are 629...and if powered with atleast 2000rms they will pound harder then he has ever known
Nowhere, OH USA
Post Number: 276
well i was thinkng a 15 ssi, so he doesnt have to upgrade electrical, he said the ssi 15 is $445, and is 750wrms, do think that would be okay? and maybe an amp suggestion??
because he has 700 to spend on sub/amp combo not just for the sub
Post Number: 1047
u could buy the pg x1200.1 the kicker 750.1 the jbl gto1201 B's amplifier the maxxsonics 1000d
but yea the treo ssi i would be a good choice if he's really into sound quality plus they do get hella loud
Nowhere, OH USA
Post Number: 278
ssi is sq? is the tsx or tsi more spl geared???
Post Number: 1049
well ive noticed from my tsx is tht it is sql oriented=....but as for the tsi i cannot say for i have never heard one
Nowhere, OH USA
Post Number: 280
so which of those 3 u think would be the best spl wise?
Nowhere, OH USA
Post Number: 285
anyone know?
Username: B101
Queen City, NC USA
Post Number: 3350
TSX will edge on the SPL if powered correctly.
SSI will have most SQ out of all
TSI is just a BABY SSI... SQ based..
Username: B101
Queen City, NC USA
Post Number: 3351
but get him a SSI 12 or 15 with a 1000D
or a TSX 15 with the 3" vc with a 1000D
flip a quater... :-)
Username: Skies
Courtenay, British Colu... Canada
Post Number: 163
is the SSX SQ oriented too?
Username: Jakeyplaysbass
St. Louis, MO
Post Number: 1165
SSX sql/spl depending on the box.
i dont really like the TSi they sound good but there pretty beginner. go with an SSi 12 or 15 and ED nine.1. it should be right around what you want to spend.
Username: Basshead86
Google is your Friend, FL
Post Number: 3805
i would get an SSi.:-)
less power required, and you know it will sound good.:-)
Username: Safe_cracker
Chicago, IL US
Post Number: 1236
If he had more money I would go with a set of SSI 10.22. I have a pair that I got stuck with (impulse buy) but I have been very happy stuck with these twins for sure, lol. I have them a little underpowered and they slam, very surprised and they fit right under the GP's back deck with lots of trunk room! I use lots of bass boost and haven't heard a peep from them. The only problem is they hit hard so they bring out extra rattles that I haven't found using 15's so I am getting some Malibu N pink lemonade and do some rattle finding tonight, lmfao...Polo.. :-O
Post Number: 3808
^^^^^.....LMAO!!!!!
i am not sure who Malibu N Pink Lemonade are....but that was funny.:-)
Chicago, IL US
Post Number: 1237
Dude try it! 3:1 ratio, lol. It's a drink fool, haaaaaaa.. :-O
Nowhere, OH USA
Post Number: 290
any other amp suggestions for the a 15' ssi???
Post Number: 1057
i would reccomend a jl 1000/1, zapco ref750.2, jbl bp1200.1, kicker kx1200(i think thts wut it is called)....oh and wut would be perfect for it i cant believe i forgot a orion 1200D
Username: B101
Queen City, NC USA
Post Number: 3352
MM2000d
https://www.ecoustics.com/electronics/forum/car-audio/239842.html
