What amp is best
Username: Tiggerboi87
Pensacola, FL United States
Post Number: 36
What is the best amp to use with the Alpine SWR-1222D
12" 1500W Dual 2-Ohm Subwoofer? Just for one right now but to be able to later on add another one. And is this sub decent?
Username: Dustin3
Tigard, Or U.S.
Post Number: 1651
kicker kx600.1
Username: Skies
Courtenay, British Colu... Canada
Post Number: 157
audiobahn a8000t
Username: Dustin3
Tigard, Or U.S.
Post Number: 1653
800 is a lil much. the kicker will do nicely
Username: Sploosh56
Ohio
Post Number: 1361
Kicker
Username: Skies
Post Number: 159
hes planning on adding another one later...
Username: Cenus
Hicksville, Ohio Usa
Post Number: 1884
kicker zx1500.1 or zx1000.1 depending on how much power you want.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1658
well, that still wouldnt work because the rms on each is 500 = at least 1000 watts.
kicker kx1200.1
tigger, if you can exchage it for the dual voice coil 4 ohm sub, you can wire the one sub to 2 ohms, and then when you get another dual voice coil 4 ohm sub, you can wire it to 1 ohm where each sub will get 600 watts (b/c it puts out 1200 @ 1 ohm)
Username: Skies
Post Number: 160
yeah.. the kx1200.1 would work great
Tigger, you have a budget?
Post Number: 37
Well actually i dont have the sub yet so i guess i can follow your advice very easily
Username: Cenus
Post Number: 1885
or just get the zx1500.1 and keep the sub you allready have, just wire it to 4ohms so it'll get about 700wrms then when you get another one wire them to 2ohms.
Post Number: 38
i sorta do im lookin for the cheapest amplifier that is still descent. I dont want to spend a whole lot.
Username: Cenus
Post Number: 1886
mtx1501d off ebay rated at 1500wrms@2ohm and very cheap.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1662
i am just thinkin that 1500 is a lil overkill for those subs. rovin says that this amp makes these subs pound. putting 1500 watts into these will be too much IMO.
IMO, i would just get the dual 4 ohm sub (b/c u havent got a subs yet right?)- then wire that sub to 2 ohms giving it 600 watts. whe you decide to add another sub, just get another DVC 4 ohm sub and wire it down to 1 ohm.
and there not that expensive anymore
Post Number: 39
hmmm ok
Username: Tjmutlow
Post Number: 2370
you either need a 1ohm mono amp or a 2 channel ran bridged 4ohm load, dual 2 sub , that is the only way you can run it, you have to dictate a budget to us, the 600.1 will not work and the 1200.1 may be to much power.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1671
well, the 600.1 will work if he only had one sub. i guess he could buy 2 of thosem one for each sub, lol.
ROVIN has the kx1200.1 on two r's and they handle them like champs. from what i have heard, its a perfect match. and anways, its only giving each sub around 600 watts. each R can handle alot more power than that. i have seen it :-)
