Like
Zapco vs Old School PPI
Username: Illuminator
Post Number: 3086
I know there's billions of these types of threads, but I haven't seen either of the aforementioned brands against each other, and haven't heard enough to really have a good idea of which is more ideal. We're assuming the old school PPI works perfectly, haha. Even if you've just heard one or the other or even neither, just give me your opinions. Thanks guys...
Username: Van_man
Boston, MA
Post Number: 483
Old Skool Zapco AG 200
Post Number: 3087
What about the newer Zapcos?
Username: Van_man
Boston, MA
Post Number: 485
unfamiliar with.. Sorry, I guess my repley is in vain
Post Number: 3088
No problem, I just need opinions. You've been helpful. I have a choice between an old school PPI and a Zapco (both rated at 450w @4ohms x1)...not sure which I want to go with...
Username: Drivingreckless
Near tampa, Florida United state...
Post Number: 789
i would take zapco over ppi any day.....zapco is built very well and puts out more thn its rated.....go for the zapco
Username: Van_man
Boston, MA
Post Number: 489
My Zapco is very user friendly. I am running 4 6x9s at 50wrms. this off a a two channel. 2 6x9, wired at 4 ohms L and R, and 2 6x9s bridged @ 100/2 for 50 watts each. I am very pleased with its performance so far. I am looking to get another soon. this is my hook up
Post Number: 795
how much did u buy ur zapco for....ive always seen them and thier expensive
Username: Van_man
Boston, MA
Post Number: 491
Username: Suleman36
Maryland U.S.A.
Post Number: 3879
I love my PPI A600.2 / its sounds amazing with my CDT component set.
I whouldnt trade it for anything.
Zapco is a excellant amp because of its build quality. Tougher then a tank and will last years to come. Reminds me of the ppi art series of the 90's.
Username: Carguy
Post Number: 5571
If you're comparing Zapco's lower models against PPI's Art series, I'd take Art.
If however, you're comparing with Zapco's C2K line, then Zapco.
Post Number: 3090
Cool, thanks for the info guys, I appreciate it.
Username: B101
Queen City, NC USA
Post Number: 3106
PPI ALL THE WAY!
Username: B101
Queen City, NC USA
Post Number: 3107
Im still searching for that same PPI amp SQ... :-)
Username: Ford150nite
Delray Beach, Fl Westplam
Post Number: 20
You want realy old school look up Force EV subs!!!!!! They knock hard as he!!.
Username: Bumpntunes01
Lewisberry, Pa York
My name is Derek, I am new on this web forum. I am very familier with both the amps. First off I will tell you the truth, the Zapco and PPI are both a hell of an amp. But I will tell you this much even though you do have a zapco, I would choose PPI any day over it.
I sold my friend down the street from where I live a 600X1 mono PPI art Series so we could power his 2 15" OLD SCHOOL lanzar DC Series dual 4 ohm, which are in excellent condition, look like they weren't used much. The amp runs them both at a 1 Ohm load, Ran Parallel voice coil to voice coil, and outside the box ran parallel to each connection chamber, the amp powers both of them to about the max handling point and still wants to give the Subs more. Amp never gets hot, stays at a nice easy warm temp, and is kickin the subs LOUD AS HELL. I know a Zapco couldn't power those subwoofers like that if it was just rated as a 600 watt mono amp. Trust me, I have used a lot of different brands in the past 8 years.
Hope you enjoy your amp.
Username: Johammbass
Cork, Cork Ireland
Post Number: 257
I have had 2 PPI Art 404's and I have also had C2K 6.0X AND Zapco will sound better 100%. Even if you compared PPI F1 series to C2K, most likely C2K would be the winner.
I love Art, but Zapco is better:-)
Arc Audio XXK will also sound better than Art.
Username: Suleman36
Maryland U.S.A.
Post Number: 3903
Im running a PPI Art A600.2 for my component set and a Arc Audio XXK-1500 for my subs.
Both are quality amps and will last a long time and sounds amazing.
Username: Detroit_fan
Post Number: 11
i've got an old ppi pc2100(no idea of output) and it pushes kickers great. been thru hell and still pounds like a champ. must admit tho, i have never used zapco
Facebook
Shop Related Deals
Directory
