Kicker sub
Username: Big_fletch
Newport, Ar, Ar United states
Post Number: 94
would a zx 1500.1 kicker amp be a good amp to push a 2006 15 solo baric L7?
Username: Southern_bass
Paris, Tennessee U.S.
Post Number: 2310
i woulldnt put that much power on it but as long as you get the dual voice coil 4 ohm sub it would work ..
Username: Ctmike
Ct.
Post Number: 782
are you the same tyler who a couple weeks ago was asking about the same question, and who first said you were powering the same sub with a power acoustic amp, then changed your story and said it was a sony xplode amp? and if you are the same person didn't you say you hit like 157db with your l7 and sony amp, but the next day said you ordered that kicker 1500 amp?
Username: Junior22
Post Number: 15
you need two dual 2 ohm subs to get full power out of that amplifier ... 2 dual 4 ohm subs can be wired to 1 ohm .. and that amp isnt stable ... at 1 ohm
two dual 2 ohm woofers can be wired to 2 ohms ...
Username: Stnorris
Eldridge, IA US
Post Number: 326
holler..what are you talking about? he said he wanted 1 L7, so give him useful information. 1 dual 4 ohm can be wired to 2 ohms. so if you get 1 dual 4 ohm L7, it would work with that amp. if that amp is supposed to be 1500rms at 1 ohm, then it should be 750 rms at 2 ohms. then they would be perfect for eachother...as long as that is the right specs for the amp.
Username: Stnorris
Eldridge, IA US
Post Number: 329
this is messed up.............
Username: Ctmike
Ct.
Post Number: 783
that amps 1500w @ 2ohm, the new kicker amps aren't 1ohm stable. so that amp will see 500w+ over the rms. i wouldn't do it, get another amp that's 750-1000wrms at 2ohm and you'd be good.
Post Number: 95
would the 1200 kx amp work? and be enough juice to push the sub hard
Username: Livin_loud
Ny
Post Number: 226
Ok, for the last time, that amp is overpowering it as it is, and if pushed hard enough will fry the sub. A kx1200.1 is plenty of power.
