Is the BOSS BL2000 any good?
Username: Ford150nite
Delray Beach, Fl Westplam
Is the BOSS BL2000 any good to power two kicker cvx 12"s?
Username: Chaunb3400
Huntsville, Alabama U.S.
Post Number: 7535
nope, maybe does 300rms
whats ur budget
No budget . So what a good amp for those subs I wanted to get every thing from kicker.
Post Number: 7536
dvc 4ohm or 2ohm???
Its a 4ohms sub. I have two .
Post Number: 8
So what amp is a good amp from kicker to power two cvx 12"?
Username: Loc_out
Santa Ana, Ca
Post Number: 416
You could use a kicker SX1250.1.
Post Number: 10
I need a 2 channel.
Username: N2audio
Lawrence, Ks USA
Post Number: 868
"I need a 2 channel."
Why do you "need" a 2 ch?
The best option IMO, and in many others' would be a class D mono amp that does around 1500w rms into 1 ohm.
You'd wire your subs like this:
Amps I'd look into --
Lanzar Opti2000D
HIfonics BXi1606D
Post Number: 17
I want a ez install like a birge 4channel or a 2channel.
Username: N2audio
Lawrence, Ks USA
Post Number: 872
it's no easier than a mono, less efficient, and for that much power probably more expensive.
but hey - who are we to make good recommendations???
Post Number: 38
A mono amp can hold that load ? how about the speakers there 4 ohms , can they come down to a 1 ohm load?
Username: N2audio
Lawrence, Ks USA
Post Number: 873
I would say the majority of class D mono amps are designed to perform best at 1 ohm - some at 2 ohms.
CVX's are dual voice coil subs. If you have dual 4's - yes, a pair of them can be wired for 1 ohm.
That's what the pic ^^ is illustrating.
If you have dvc 2's wired for 4 ohms a piece then you want an amp that's around 1500w at 2 ohms or 1/2 ohm.
Post Number: 41
don't class D amps sound bad in the highs?
Post Number: 7648
"don't class D amps sound bad in the highs?"
Nope, not at all
Username: N2audio
Lawrence, Ks USA
Post Number: 874
12's don't play hi's
class d amps are used in world-class SQ set ups -- I really don't think sounding bad in the highs will be a problem for you.
Username: N2audio
Lawrence, Ks USA
Post Number: 875
chauncey, sure they do - the switching of the outputs becomes audible above a few hundred hz. It's beside the point though - if 12's are playing a few hundred hz or higher that's a problem.
Post Number: 42
by sounding bad i mean like distortion . Is a class D amp like http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=17036 going to make the subs sound bad ?
Post Number: 43
I still don't ubderstand how a one channel amp can power two subs?
Username: Rick_ross
Post Number: 50
you hook two subs up to one channel idiot
Post Number: 44
show me a pic fake rick ross!
Username: Johammbass
Cork, Cork Ireland
Post Number: 238
Optidriven,
So which "world-class" SQ set ups are using D class amps?
I am pretty sure that MOST "world-class" SQ set ups are using 2ch bridged for their subs:-)
Post Number: 50
Want iam trying to say is that I want to hear the music when the vol is low with some bass.And then when my friends come over I can slam it. To hear the bass!
Username: Juliob
Santo DomingoDominican Re...
Post Number: 676
robert i think you're pretty dumb! use one class D amp, they're for subs!!!!!! you can say they will sound bad if you're using one class D with some 6x9 speakers or tweeters, but not with subs!!!!!!!!!!
Username: Rick_ross
Post Number: 51
put both - wires and both + wires from the subs into the one channel on the amp. how dumb can you get
Post Number: 52
rick ross go away !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Username: Gangstafert
Post Number: 120
Robert just listen to these guys they know what they are talking about. The mono amp will be alot better for your subs wire them like that pic shows and you will be set, and they will slam for your ftriends.Its also more efficient.
Post Number: 53
ok thanks man
Username: N2audio
Lawrence, Ks USA
Post Number: 877
"So which "world-class" SQ set ups are using D class amps?
I am pretty sure that MOST "world-class" SQ set ups are using 2ch bridged for their subs."
Sorry, haven't done any show-to-show surveys. We both know they're out there. I didn't say MOST use them, I didn't even say a lot.
And some that DON'T use them will still tell you there's no audible difference in the sub frequencies.
My only point was there is no significant drawback in SQ by using class D vs. a/b.
Certainly not for Joe Blow trying to come up with a decent system for the DD.
Username: Fandim
Reno, Nevada United State...
Post Number: 1165
I gotta go with Optidriven on this one.
