Hey B
Username: Alteraudiousa
Concord
Post Number: 842
when you upgraded your alt, did you upgrade the factory fuses? Thats alot of fuses to change out.
Username: Safe_cracker
Chicago, IL US
Post Number: 1166
No why would you? Your factory electrical will always only draw what it needs UNLESS there is something wrong, hence the need for fuses. You actually are not really hooking up anything to the factory wiring so it is all good..:-)
PS- Sorry, I am not B but I figured I would get the answer to you quicker.. Polo. :-O
Username: B101
Queen City, NC USA
Post Number: 3048
no, no need to upgrade any factory fuses...
there is only 1 direct connection to the alternator, and thats the charging wire that goes to your battery positive terminal!!
The alternator control wire, will just monitor the alternators output, and display it on your dash, if u have a batt meter built into the instument panel..
but yeah, what Polo said... the car will only pull, whats needed... so with the 200a HO, it might still only want 40a... the rest to the system, and it will pull what it needs..
Call me if u need help when u get it...
Username: B101
Queen City, NC USA
Post Number: 3049
BUMP@!!!
Concord
Post Number: 845
cool, I talked to Nathan today and I think i'll be ordering one soon. It was like 300$ shipped which isn't bad at all. I'll have to get it after I test out the Hybrid Audio Legatia L3's.
Username: B101
Queen City, NC USA
Post Number: 3050
yea, thats a good price, especially on a Import...
whats this "hybrid audio legatia l3s"
Concord
Post Number: 848
www.hybrid-audio.com
I hope to have it soon like Thursday. It looks like a promising driver and hopefully fit my needs.
Username: Basshead86
Google is your Friend, FL
Post Number: 3622
those Legatia 62's look SWEET!!!:-):-O:-):-O
Los Angeles, CA USA
Post Number: 4010
wassup muddy.
alteraudio....i left all my factory wiring and fuses alone. i just added 0 gauge cables.
Username: B101
Queen City, NC USA
Post Number: 3069
Polo, u got mail... :-)
yea, Alteraudio, those Legatia's look real impressive, never seen a driver quite like these... I bet they sound delicious..
hey Muddy, how come your not up early anymore? get at me!
