Orion 2500d ??
Username: Gl0ck
Post Number: 9
i got this off ebay and hooked 1 supply up just to make sure its not doa and it powers on but barely puts out any wattage.
will it put out all wattage with both supplys compared to doing basicly nothing with one?
Username: Johammbass
Cork, Cork Ireland
Post Number: 149
Hook it up and see, I guess.
Username: Bp317
Post Number: 80
hah, i was gonna start a thread on this. Im gettin my 2500d tomarow and dont have a distro block yet and was wondering if hookin up one of the power supplies would still work.
Username: Gl0ck
Post Number: 10
well i think my amp is junk barely pushes my type x at all...very bad sq coming from it.
Username: Rovin
Trinidad & T...
Post Number: 7966
um - y would u do something like hook up only 1 power supply !?
orion is not junk - get it powered right & wire up ur sub properly & enjoy
BTW - that amp is going 2 need some serious current so read http://www.wickedcases.com/caraudio/charging.html
Username: James_g
TN
Post Number: 491
Just branch off your power wire temporarily and run to the other supply. Then you'll know.
Just curious. What size power wire are you using right now?
Username: Van_man
Boston, MA
Post Number: 362
More importantly what size ground?
Username: Bp317
Post Number: 81
well right now i dont have a distro block but i ordered a fused one earlier today. would it be ok to run just one power supply for a little while? Im gonna run 0 gauge to 2 4 gauges. and i plan on getting a new alternator soon.
Username: Van_man
Boston, MA
Post Number: 370
Use one feed from the battery to it but power both supplies with it. Even if you use a 3" jumper for now. running 0 to 2 4 is good. aslo use 0 for your ground then.
Username: Dustin3
Tigard, Or U.S.
Post Number: 1227
^^ anyting smaller than 0 ground is bad and will not get efficient current to the amp. expess, for 2500 watts
