Head unit with steering wheel remote capability?
Username: Botchki
Looking for a good Head unit high in SQ with Steering wheel remote capabilities...any suggestions would be greatly appreciated. Price range up to around $450. Thanks.
Username: Tjmutlow
Post Number: 2051
you still need to buy the add on piece for steering wheel controls....
Username: Botchki
I already have steering wheel controls with the factory head unit I have now, so do I still need to buy an add on piece?
Username: Tjmutlow
Post Number: 2054
yes, the pesswix piece from preiphael
Username: Botchki
Help! what is the "pesswix piece from preiphael?" I was told today at audio king and again at another retailer that there is no way to use the steering wheel controls with an aftermarket head unit.
Username: Tjmutlow
Post Number: 2056
what yr make and model of car....
Username: Botchki
Its a 1999 Saab 9-3
Username: Tjmutlow
Post Number: 2077
all you should need is the peswix piece, go to ebay and search for item # 9727852886
Username: Kpowers
Post Number: 22
Do I need a pesswix to make my steerwheel contrlos work with my '01 Cadillac DeVille?
is a pesswix unique to for different autos?
Username: Botchki
Another question if anyone wants to chime in and help. I'm going to buy a pair of Polk Audio SR6500's components (unless I change my mind or someone can suggest something better that I can get for around the $450 that I can get them). What else do I need for a good setup. the car I am putting them in currently has some lower grade Alpine front and rear powered by an alpine MRF-320 amp, and a Jl audio 10" sub. If I put in the SR6500's, do I keep the rears or switch them out as well and how do you coordinate the sound of different speakers? I am really only looking for as good of SQ as I can get for my budget, and listen to alot of vocals, jazz, alternative. Any help would be greatly appreciated.
Username: Tjmutlow
Post Number: 2079
the peswix is not for just any car, it is a universal piece...
Username: Johammbass
Cork, Cork Ireland
Post Number: 77
This one will sound better than Polk
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1139
These would prob do better than Polks as well
or get DLS Iridium or UR on Ebay
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=1104
