Silver Member Username: Van_manBoston, MA Post Number: 322 Registered: Mar-06 | I looking to build a new box for my 12" L7 Im toying with this design. It will be tuned to about ~35hz And 3.5 cf. I just got to figure all the logistics out.Port lengt, Size. (jump in if you want) Anyway, whats the diff of mounting the Sub inverted? Thanks. BTW accalorate pedal is down I think. |
Silver Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 452 Registered: Apr-06 | http://wickedcases.com/caraudio/inverted.html read real quik should answer ur question... |
Gold Member Username: GoatinOhio U.S.A Post Number: 1078 Registered: Jan-06 | looks and it gives your box a bit more air in the box. |
Silver Member Username: Van_manBoston, MA Post Number: 324 Registered: Mar-06 | Thanks, Well now on to the math. |
Silver Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 453 Registered: Apr-06 | how long is the port.... were did u calculate this at or is this just an overview of wut u are hoping of building?????? |
Silver Member Username: Van_manBoston, MA Post Number: 326 Registered: Mar-06 | Just an overview... I want to make it a cube to match the L7 design Im thinking ~ 18x18x18. I need to find a program or something to try and get it at 3.5cf tuned to ~35 winsled or whtevr wont run for me for some reason, and that other Pedal thing is down or busy. Zapcoe may be hogging it right now. Lol |
Silver Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 454 Registered: Apr-06 | http://www.carstereo.com/help/Articles.cfm?id=31 try this one |
Silver Member Username: DrivingrecklessNear tampa, Florida United state... Post Number: 457 Registered: Apr-06 | didnt bump!! |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 1138 Registered: Jan-06 | Try with the port on the bottom running horizontal to you vehicles floor pointed to rear and sub on top the way you have it. Polo. |
Silver Member Username: Van_manBoston, MA Post Number: 328 Registered: Mar-06 | Anyone have any input before I make yet another box. 3rd sub, 3rd box. |
Silver Member Username: Van_manBoston, MA Post Number: 330 Registered: Mar-06 | Sorry for the bump however, Is 35 a good tuning for L7 ? my current box is at 30 but I see some ppl going up to 40. What is a good daily driver setting? Thanks Does any one see errrors with my calcs? Did it by hand, couldnt find a site to just plug and play. Does any one else having trouble getting into Accped.com site.? |
Silver Member Username: Van_manBoston, MA Post Number: 331 Registered: Mar-06 | Yea, thats exactly what I was thinking... |
Bronze Member Username: Roy_tPost Number: 97 Registered: Feb-06 |
