ARE THESE SUBS ANY GOOD
Username: Reef
Post Number: 38
are VOLFENHAG subs any good
Username: Basshead86
Google is your Friend, FL
Post Number: 3337
NO.
Username: Reef
Post Number: 39
how about legacy
Post Number: 3339
NO.
Username: James1115
Ct
Post Number: 5871
whats your budget just for subs and we will point you in the right direction.
Username: Reef
Post Number: 43
wat about orion H2
Username: Splmonster
Post Number: 33
dont that have like a 2000wrms rating? quite a jump lol, like he said give a budget so everyone can suggest best for the money setup
Username: Reef
Post Number: 44
im thinkin aroun 100-250 for a pair of subs
Username: Young_james
Post Number: 1478
spl or sq?
Username: Sw9152
Michigan
Post Number: 675
2 kicker 15" cvr's for about $200 on ebay. good budget subs. they get loud and still keep some sq.
Username: James1115
Ct
Post Number: 5873
alpine type r's, vega v-max's, Image dynamics IDQ's, does it have to be 2 subs or would you be willing to do 1 better sub?
Username: Reef
Post Number: 48
yea i was thinkin about getting 1 sub that will beat 2 12s but i dunno wat to get i dunnno wat brands are good because every one has diff sayins about brands
Post Number: 38
listen to these guys, they know there stuff
i think u should get the type r's they are here for like 115 each, alittle more but worth it
http://carstereoexpo.com/swal12tysesu1.html
Username: Reef
Post Number: 49
wat does spl and i know sq means sound quality right and i think spl means sound pressure level right? wat does that really mean
Post Number: 41
sq is how clean it will sound and spl is pure bass, like when it hits u cant hear the music lol
and SQL is a nice mixture of both the type r's are SQL
Username: Reef
Post Number: 50
haha i want a sub or a pair that are SQL and i am making a custom box wat should Frequency should i tune my box to im not sure how to tune the box so the subs sound the best? help pleaee
Post Number: 48
well thats as far as my knowlege goes so far dont wanna steer ya in the wrong direction, but first pick out some subs then people can tell you what to tune them to, and tuning has to do with the box design. and u only need to tune it if ur going ported, so find the subs you want and go from there. if you take my advice on the type r's get a nice 1200 watt amp ( lots will back up the r's ) like the ed nine.1 or the kicker kx1200.1
type r's are good sql cvrs are more spl and dont sound nearly as clean as the r's, but not sure bout the other subs he posted, get some feedback from ppl who have heard lots of them
Username: Reef
Post Number: 52
yea i dunno if i wanna go ported or not because my car is a 1985 camaro hatch and there is a cubbie in the very back and i dunno if the box would be big enough for 12s with a ported enclosure, u mean 1200rms right. i was thinkin about a hifonics amp
Username: Reef
Post Number: 57
i found some new piooner subs here is the model number Pioneer TS-W3004SPL do you think gettting 2 of these would be better than the CVR, i am lookin for SQL
Username: Rovin
Trinidad & T...
Post Number: 7833
Yes those 3004 r low priced & get loud
BUT !
think about how much an amp 2 power them will costs & also more $ on upgrading ur electrical 2 supply the needed current ........
Username: Reef
Post Number: 59
true, but you think there gunna be louder than the CVRs or typeRs, so wat you mean bye upgrading electrical system? like a higher amp alternator,
Username: Rovin
Trinidad & T...
Post Number: 7836
http://www.wickedcases.com/caraudio/charging.html
Username: Reef
Post Number: 60
k thanks, does any one think i should buy these over the CVRs or type Rs
Username: Ctmike
Ct.
Post Number: 536
you want sql, i'd go:
type r
cvr
pioneer
Username: 420pimp2
Post Number: 726
buy type r's i don't hear alot of bad sh.it about these subs i hear mostly good sh.it so type 'rssssssss would b the way 2 go
Username: Reef
Post Number: 62
should i got with a sealed box or a ported
Username: Livin_loud
Ny
Post Number: 103
Sealed = ~4 dB less than ported but tighter bass
Ported = Louder, lower, boomier bass
Your choice
Username: Ctmike
Ct.
Post Number: 539
ported.
Username: Reef
Post Number: 63
i was hopin you would say sealed haha tuning the box seems confusing, i wouldnt have a problem with buiding the box but i dunno about the tuning wat should i tune it to. i want boomie bass, i have another question so lower the frequency the lower the bass? and i dont really ge dB so if a subs is 90db and another sub is 87dB would the 90dB be louder i dont really get that
Username: Rovin
Trinidad & T...
Post Number: 7841
if u port loooow like 30/32Hz u can get VERY NICE tight accurate bass like i'm currently getting with my RS
if u port higher like 35/36hz & up the u will get boomier & lose some SQ .......
Username: Ctmike
Ct.
Post Number: 540
yep^^
and yes 90db. is louder than 87db.
read this to learn more
http://www.bcae1.com/
Username: Reef
Post Number: 64
can you explain the dB please
Username: Reef
Post Number: 65
ok thanks
Username: Ctmike
Ct.
Post Number: 542
look at that site i gave the link for under decibel on the right.
simply put, higher db. louder.
Username: Mixneffect
Orangevale, Ca. USA
Post Number: 907
Db = deci-bell = 1/10 of a bell
Alexander Graham Bell invented the telephone. It had a speaker. In order to measure its efficiency per given watt, Alexander Graham Bell invented the "bell" unit of measure. Since this measure was too great for rating a speaker, it had to be fractioned. What better way then the metric system. So he divided them into tenths, therefore deci-bell.
Sound Pressure Level is measured in decibels.
Yes sound is measured by the pressure it generates, and therefore pushing on our eardrums.
So a 87 dB speaker will be softer than a 90 decibel speaker, given that they are capable of handling the same wattage, have the same resistence (ohms) and are the same in all other aspects other than efficiency (dBs).
Orangevale, Ca. USA
Post Number: 908
http://en.wikipedia.org/wiki/Alexander_Graham_Bell#Bell_and_decibel
Correction;
Bell and decibel
The bel (B) is a unit of measurement originally proposed by 1929 W. H. Martin of Bell Labs (Bell System Techn. Jrnl. VIII. 2) and named after Bell. The bel was too large for everyday use, so the decibel (dB), equal to 0.1 B, became more commonly used.
Username: Reef
Post Number: 66
So higher the db there louder is will be so when looking at subs should i look at that to
