Help with ohm's
Username: Hockeyknight
Post Number: 119
i want to run 2 10" cvr. should i get the 2ohm or the 4 ohm and what would be a good amp for it? i want to do it cheap like $150 for the amp.
Username: Rollout4877
Kent, Ohio USA
Post Number: 25
2 ohm will push more power
Post Number: 120
k well what subs should i get??
Username: John_wash
Nashville, Tennessee
Post Number: 248
i dont think thats true Roll Out
Post Number: 121
correct me if im rong bit to do this the cheapest rout i should get the 2ohm subs and wire them in parrellel and get a mono amp that runs 600 rms @2 ohm stable. or is there any way to run 2 subs with an amp at 1 ohm? I DONT GET OHMS GRR! haha im soo confused HELP
Post Number: 122
whats a good amp for 2 cvr's
Username: Rovin
Trinidad & T...
Post Number: 7689
buy 2) 12" 4ohms dvc version & this amp
http://www.onlinecarstereo.com/CarAudio/ProductReview.aspx?ProductID=14965
Username: Ctmike
Ct.
Post Number: 409
thats a pretty small budget. try checking ebay for something that'll give each sub 350-400wrms.
and yes you can run 2 subs off 1 amp at 1ohm, depends on which sub you get, the dual 2 or 4vc version.
http://www.crutchfieldadvisor.com/learningcenter/car/subwoofers_wiring.html
