Say i have a cvr and i think they are like 26hz or sumthing, the manual said in you wanted to build the spl/deepbass vented enclosure it was tuned to like 40hz but someone told me to tune it to 32hz. Whats the big difference between those two? For better sq do you go lower? Thanx muddywaters...
Thanx Muddywaters u da shizznit! Would you tune a cvr about 32hz? If i listen to nuthing but rap and i like those bass notes on songs such as late nite tip, throw it up, da blow, and others like that what should i go for sq or spl? What should i tune it to? Thanx!!!!!!!!
The sub peaks out at a little below the tuning frequency of the box. I listen to all rap, and i tuned aroun 32hz for my 15. I would say listen to muddy and do about 35hz. The difrence is that the sub will move out of control on notes below the tuning frequency of the box. HIgher tuned is generally for SPL(mid 40hz.) and lower tuned for SQ.
3.5 cuft tuned @ 32hz 3inch slot port for a 15 cvr hit hard an for 2 12 cvr a 5cuft tuned @ 24hz with a 2 inch slot port hit hard sounds go0d as hell an hear it far an great sq i made the box for the 15 an the 1 for the 2 12s an the 24hz port is best on the rap great with da blow beat kicks @$$ an loud by ear
